Post by stevednorris on Apr 23, 2017 15:13:07 GMT
Did you pass the IVA ok with your screen fitted and did you put any trim on it?
Post by brettlawrence on Apr 24, 2017 6:31:05 GMT
Yeah screen was fitted. I had trimmed it a little to ensure that it was below line of sight. I also spent time giving the top a radius, with emery and then t-cut. Tester mentioned that it wasn't strictly radiused enough but it passed. It's comforting to know that I trimmed it enough to not be a windscreen but I'd be tempted to leave it off if I was doing it again.
Post by stevednorris on Apr 24, 2017 8:09:35 GMT
Thanks, think I might leave mine until later then.
Post by Stiggy on Apr 24, 2017 21:37:14 GMT
I always say leave it off for IVA as sometimes you are asked to prove it won't shatter even if it is low enough and radius is 2.5mm. It's very easy to slip when sanding a rad on the edge and cause a scratch to the front. Been there done that! Knock on trim looked a bit naff when I tried it. If it hasn't got a screen it's one less thing for testing, maybe we should get a discount, Replicar is soooo easy for the inspectors, they could do 8 per day instead of 2 !
Post by brettlawrence on May 4, 2017 17:37:43 GMT
I see lots of people sending proof of insurance with their V55/5, even though the form states : The guidance on the website www.gov.uk/vehicle-registration/new-registrations is more ambiguous, stating : Which could be taken to mean you need an insurance certificate unless you are in Northern Ireland in which case a cover note will do, but that's twisting it a lot. The V355/5 guidance form for the V55/5 does not mention anything re. insurance. I'm not planning on sending proof of insurance. Any one had a problem with this?
Post by Deleted on May 6, 2017 15:55:23 GMT
A specialist insurer will issue a policy using the VIN as you don't have a reg yet. Can't remember what I did with the Westfield but as I had insurance I probably included it. You won't get it taxed without insurance so sending it could help speed up the process. The less time you spend dealing with DVLA the better.
Post by brettlawrence on May 7, 2017 8:10:59 GMT
Aah of course, good point about the tax. Cheers.
Post by brettlawrence on Jun 7, 2017 15:49:18 GMT
I received my v5 and reg number today.
I can confirm that you do not need to include insurance even for tax when registering. I have a tax slip and I did not insure the vehicle. So if you want to go that route, it should be ok.
They did however not return my IVA, so i'll be calling about that.
Post by brettlawrence on Jun 8, 2017 11:04:54 GMT
Mea culpa, IVA is not expected to be returned from DVLA.
Post by Deleted on Jun 10, 2017 14:51:26 GMT
My IVA certificate was returned but several months later so you might get it back.
Post by brettlawrence on Jun 12, 2017 19:53:58 GMT
Good to know, cheers westie. First drive: 20 mile shakedown, just need to tighten rear view mirror mounting. Then new wheels, suspension etc etc blah blah. God it's fun, made it all worth it. Feels like a really tight and agile mx5, crazy amounts of road feel and even more steering input responsiveness.
Post by brettlawrence on Jun 16, 2017 13:41:20 GMT
I've lost 2 baseball caps so far.
I keep finding myself in a gear above where I would have been. Instead of sitting in 4th on some country road and dropping to 3rd for a blat when the opportunity arises, I'm sitting in 5th and only realising when I drop to 4th and it still pulls. Dropping to 3rd instead causes all sorts of extra excitement. I'm sure it's mainly the massive weight saving, but I think the lighter flywheel helps a bit as well.
It does kind of have a heater built in, all the hot engine air enters the cabin between the body and dash at the top, and around the sides of the footwell. Noticeable and pleasant in the summer. Not sure if there will be any effect in the winter.
Just one ugly clunk under certain loads to look at. It really is hilarious fun.
Post by gwnwar on Jun 18, 2017 2:26:54 GMT
Get a couple of small pinch squeeze clips and about 6" of elastic strip 1/4" wide.. Fasten clip to each end.. clip one end on back of hat other to collar of shirt.. Might just be an exhaust tube rattle check your rubber donuts.. You can tighten them up by putting a screw clamp around them..
Post by brettlawrence on Jun 18, 2017 9:48:55 GMT
Get a couple of small pinch squeeze clips and about 6" of elastic strip 1/4" wide.. Fasten clip to each end.. clip one end on back of hat other to collar of shirt.. Hah great idea - thanks Clunk hunting tomorrow, will check exhaust mounts...
Post by brettlawrence on Jun 19, 2017 17:41:04 GMT
Some small quality of life additions, can't live without oil temp. Added essential air freshener for that new car smell and a dash mounted navigation system.
