Post by gwnwar on Dec 20, 2014 8:38:13 GMT
Go a head and put the bushings in the diff housing..If you get a Torsen all you have to do is swap the center section out.. Housings are the same..
montgom
Love Exocet
Post by montgom on Dec 20, 2014 19:45:32 GMT
I finally got a few minutes to work on the car today and I was able to install all of the suspension bushings and the ball joint boots. Next up are the diff bushings. I haven't done them yet becaus I keep thinking that I will find a reasonable deal on a Torsen but I think I am just going to go ahead and replace the seals and bushings and install the open diff I have. I am sure as soon as I do the perfect Torsen will pop up on craigslist. I am in awe over the beauty of the work you are doing. WOW!!! Robert
Post by ImprobableConstruct on Dec 21, 2014 0:13:31 GMT
I didn't get much done on the car today. This morning I put the rear wheel bearings in the freezer and this afternoon I installed them in the uprights. I was hoping they would just drop in but no such luck. So over to the 20 ton press I went. I picked up a U.S. General 10 Piece Bearing Race and Seal Driver Set the last time I was at Harbor Freight for about $30 with a 25% off coupon. The Blue 72mm disk was the perfect size for the bearings. I then flipped it over and used the black 81mm disk to press in the axle seal on the back side. Here are the finished uprights: Sooner or later I might get around to that rear diff...
montgom
Love Exocet
Post by montgom on Dec 21, 2014 17:20:02 GMT
You do really nice work. Robert
Post by einy on Dec 22, 2014 11:40:44 GMT
I.C - I am curious for an 'observation' from you when you get the front suspension re-assembled. When you do, please let me know what rotates relative to what on the upper control arm pivot points, when you move those arms up / down. For instance, do the poly bushings rotate relative to the (new) steel inners sleeves? I have the Energy Suspension kit installed on mine, and this is what I am seeing on my setup, and regardless of how much grease I put between these two parts, the already squeak and somewhat bind up. No noise / no binding on the lower control arm bushings - just on the upper. I do have the long thru bolts torqued to factory manual specs (cannot recall exact value as I sit here at work right now - but it is on the high side).
Any input from direct experience would be GREATLY appreciated !!
Post by ImprobableConstruct on Dec 23, 2014 0:43:22 GMT
Not much progress today. I painted the hubs and installed the ARP studs. I also finally got around to ordering the little big brake kit from FM and some V Maxx coil overs. Unfortunately some little part is back ordered so the brakes will not ship until sometime after January 5th. My frame should be welded up and in line for powder coating at this point, but I have not had any emails from Exomotive. I also have a line on a 4.1 Torsen 1 from a low mile 95 m edition that was wrecked. I am supposed to pick it up tomorrow on my way to the in-laws for Christmas.
Post by ImprobableConstruct on Dec 23, 2014 0:45:03 GMT
I.C - I am curious for an 'observation' from you when you get the front suspension re-assembled. When you do, please let me know what rotates relative to what on the upper control arm pivot points, when you move those arms up / down. For instance, do the poly bushings rotate relative to the (new) steel inners sleeves? I have the Energy Suspension kit installed on mine, and this is what I am seeing on my setup, and regardless of how much grease I put between these two parts, the already squeak and somewhat bind up. No noise / no binding on the lower control arm bushings - just on the upper. I do have the long thru bolts torqued to factory manual specs (cannot recall exact value as I sit here at work right now - but it is on the high side). Any input from direct experience would be GREATLY appreciated !! I will let you know what I find out when I get the roller skate put back together.
Post by lhintze on Dec 23, 2014 0:52:34 GMT
I just got my brake kit and have the same parts back ordered, the wait begins. See pics in my thread...
Post by ImprobableConstruct on Dec 23, 2014 2:40:41 GMT
I just got my brake kit and have the same parts back ordered, the wait begins. See pics in my thread... I saw your post. What exactly is back ordered? They said it was some sort of adaptor.
Post by lhintze on Dec 23, 2014 2:43:58 GMT
I'm not sure either, I think the adapter goes from the NC brake lines to the levers on the calipers for the parking brake.
Post by ImprobableConstruct on Dec 23, 2014 2:54:08 GMT
Hmmmm. I think I am going to call in the morning and just have them ship whatever they can. I am sure that whatever is missing I can install when it becomes avalible.
Post by lhintze on Dec 23, 2014 3:02:20 GMT
That's what I had them do, they said the parts on back order will require you to remove the caliper, but you won't need to open the lines and rebleed the system.
Post by einy on Dec 23, 2014 11:31:03 GMT
Regarding the extended length wheel studs - are you anticipating having to use a spacer >5mm in thickness? From what I'm seeing elsewhere, if 0 offset wheels are used with ~ 205mm wide tires, no spacer is needed for the fronts, and a 5mm is needed for the rears. Looking at spacers on the FM website, they say standard wheels studs are OK for up to a 5mm spacer (although recommended for track use) ... wondering if I need to be making this change also, although primary intended use (for now) of my Exocet will be street.
Thoughts ??
Post by greg on Dec 23, 2014 11:51:38 GMT
I got 5mm spacers for the rear only because Warren recommended them for the fenders.
Post by ImprobableConstruct on Dec 23, 2014 14:03:58 GMT
When I picked up my donor it had at least one broken stud on each hub and I broke another one off removing the wheels for the tear down. So for me it was an easy choice to just get the ARP studs and be done with it. With the 0 offset wheels the studs will not stick out past the rime even if they are pretty long. I am waiting on spacers at the moment and will figure out what I need after I get my brakes. According to the templates on the FM brakes page, the calipers will hit my rims, but others here have the little big brake kit with holeshots and they clear. So I am not really sure what's going on there.
