Post by lhintze on Jul 5, 2015 0:18:39 GMT
Both sides did that, I did make sure to stuff it full of grease while reassembling. Thanks for the heads up!
Post by lhintze on Jul 5, 2015 23:35:34 GMT
Got 2 extra quik latches if anyone wants em, $40 shipped.
Post by einy on Jul 6, 2015 17:04:53 GMT
Luke - are the Quik-Latch mini's just too small to use on the rear of the hood (where you used the Aero Latches)?
Post by lhintze on Jul 6, 2015 18:15:28 GMT
I ordered 4 to see if I wanted to use them all in addition to the aero latches. If I positioned the hood 1/2" more forward they would have worked, but the hood is now too close to the body mounts.
They could be made to work in the back, just might have to thread them into a standoff to make them taller.
Post by ImprobableConstruct on Jul 6, 2015 22:50:04 GMT
I ordered 4 to see if I wanted to use them all in addition to the aero latches. If I positioned the hood 1/2" more forward they would have worked, but the hood is now too close to the body mounts. They could be made to work in the back, just might have to thread them into a standoff to make them taller. I used 4 of them to mount my hood. I ordered the 4" long 5/16" thread posts for the back of the hood.
Post by einy on Jul 7, 2015 0:32:57 GMT
What size did you use on the front of the hood, IC ?
Post by lhintze on Jul 7, 2015 1:14:56 GMT
I'm not 100% on what you mean, I used 2 of these on the mounts by the top of the radiator then 2 1/4-20 bolts thru nut clips down near the bottom of the radiator on either side. Clear as mud?
Post by ImprobableConstruct on Jul 7, 2015 1:38:37 GMT
I used two next to the top of the radiator, two next to the firewall with the extended pins and I just put some foam on the bottom front mounts to keep the nose from shaking.
Post by lhintze on Jul 9, 2015 0:24:22 GMT
Got my fuel fill today, finished running the fuel hose and wiring the licence plate lights into the tail lights as well. I made a backing plate with the same hole spacing to go under the trunk and act as a washer. Last thing on the list is to mount the fenders!
Post by ImprobableConstruct on Jul 9, 2015 1:13:55 GMT
I went with that same fuel filler and I think I have very similar plate lights on the way.
Post by gwnwar on Jul 9, 2015 3:40:41 GMT
Nice clean install and look, filler and lamps.. like the tail lamps..
Post by lhintze on Jul 9, 2015 10:26:38 GMT
^thank you
Post by lhintze on Jul 11, 2015 18:50:24 GMT
Got the car inspected today and will head to the dmv Tuesday to get the plate. I added the Exocet to,the insurance policy, it is $320 for 6 months full coverage, valued at $25k. Here are the pics I'll give to the dmv of the car:
Post by gwnwar on Jul 11, 2015 19:51:19 GMT
Bad a$$ looking from the front.. Like the windscreen mount looks real pro..Have you set the toe yet looks toed out in pics maybe just the pic.. Great price on insurance and coverage..
Post by greg on Jul 12, 2015 12:11:57 GMT
Who is your insurance provider? I'm paying $220 a year for the same coverage.
