Post by sandancer73 on Sept 22, 2014 11:26:57 GMT
KOTT, I've used the mk1 donor handbrake and cable without any pulleys and it appears to work fine (unless I've missed something).
Post by kingofthetwisties on Sept 22, 2014 13:20:53 GMT
Cheers, glad it's not just me then. I reckon I need two lines about 120cm long to sort the rear lines. Just had a call from RTR after they saw my post. They have explained how the lines in the pack are meant to fit and I now see why they are that length. However, as part of the build I wanted to route the lines around the chassis rather than leave them loose and trailing over to the rear swing arm. I explained what I wanted to do to the guys at RTR and they fully understand what I’m aiming to achieve. As a result they have offered to supply longer lines for me so I can route the lines round the chassis as planned. Great service and shows flexibility to help people with different build ideas.
Post by kingofthetwisties on Sept 22, 2014 13:21:41 GMT
KOTT, I've used the mk1 donor handbrake and cable without any pulleys and it appears to work fine (unless I've missed something). Is the cable not routed from the opposite side?
Post by sandancer73 on Sept 22, 2014 21:12:43 GMT
No, you need to swap the calipers over (bleed nipple facing down) and swap the handbrake arms back to the original sides (facing forward).
Post by Paul (madeye) on Sept 22, 2014 21:19:52 GMT
how does that work? bleed nipples down? that's against physics.
Post by kingofthetwisties on Sept 22, 2014 21:53:30 GMT
No, you need to swap the calipers over (bleed nipple facing down) and swap the handbrake arms back to the original sides (facing forward). That's different, with the mk2 lever you just need to take out 35mm and weld the two pieces together. I have a pic somewhere, I'll post it when I find it.
Post by kingofthetwisties on Sept 22, 2014 22:46:00 GMT
No, you need to swap the calipers over (bleed nipple facing down) and swap the handbrake arms back to the original sides (facing forward). That's different, with the mk2 lever you just need to take out 35mm and weld the two pieces together. I have a pic somewhere, I'll post it when I find it. Here you go Ive not done mine yet but the pics show one that Steve did and fitted
Post by kingofthetwisties on Sept 29, 2014 15:37:06 GMT
Well it's a sad day today. I'm about to move house and the new gaff does not have enough room in the garage for me to work, so the Rocket has gone into storage. When I'm in a new workshop is being built so I'm hoping that she will only be away for about four weeks.. Until that point there will be no progress on my build.
Post by mawdo81 on Sept 29, 2014 16:31:31 GMT
Can you start on the wiring set up to keep the itch scratched?
Post by kingofthetwisties on Sept 29, 2014 17:42:43 GMT
Can you start on the wiring set up to keep the itch scratched? Sent from my GT-I8190N using proboards Not sure, I need to collect my loom from RTR and see if I can work it out.. It's worth a go
Post by kingofthetwisties on Sept 17, 2015 19:53:20 GMT
Well that was a long four weeks. It's been a year since I did any work on my Rocket. The house move threw up many more challenges than I thought but I have now taken the Rocket out of storage and although my workshop is not as big as I would like at least I can start a bit of work again. Reckon I'll get a bit done thus weekend. Can't wait. Watch this space
Post by kingofthetwisties on Sept 20, 2015 18:25:49 GMT
Well I got a few hours work done on her today. Unfortunately I've gone backwards though as while she was in storage for a year I had thought about a few different ways of doing things so I have been taking stuff off and re doing things. Patience is a virtue.
Post by rcsimon on Apr 30, 2018 18:08:29 GMT
So I have purchased this build from Anton. He hasn’t touched it for over 2 years and it needs some love. I intend to give the car that love. It has some rust on the chasis which needs sorting fairly soon incase I need to strip bits off. The engine needs some bits sorting and that is my priority as I want to get it in the car and then start plumbing / wiring. I will be getting my head around the bits I have bought with the car and the work I need to do before jumping in with the work. So engine has gone to a friends garage for a timing belt and I am tidying the garage and sorting out tools. Will keep the board up to date with my progress
Post by carlyd on May 2, 2018 14:49:22 GMT
Congrats on the purchase. I'm looking forward to reading about another build. my advice? just enjoy the build!
Post by rcsimon on Jun 5, 2018 10:49:23 GMT
I am now getting my head around the build - what goes where and how it all fits together. It was daunting at first and thought I might have bitten off more than I can chew. I am much happy now (2 months of ownership) and really enjoying the build. I have sourced a box and got the engine ready to go in. I was going to fit it on Saturday but the hoist I had borrowed had dry seals and did not work. Not a bad thing as we looked at the brakes and best to get them all finished before the engine and box make access difficult. Photos to follow.
