Post by james13009 on May 4, 2016 19:06:41 GMT
Bit of an update.
Post by p5curly on May 5, 2016 9:00:22 GMT
Looking good james I will have to pop round to check it out
Post by Mills Extreme Vehicles on May 5, 2016 11:17:21 GMT
pop a few pics up James and we can all voice any IVA concerns that may help you, interior mirror for instance and I suspect you may have to mount different wing mirrors that stick out to clear viz over the rear wing.
Post by p5curly on May 5, 2016 11:40:52 GMT
You don't need interior mirror for Iva
Post by Mills Extreme Vehicles on May 5, 2016 12:07:36 GMT
You don't need interior mirror for Iva WRONG !!
Post by p5curly on May 5, 2016 12:14:29 GMT
How does it work in a rocket then all you see is the engine
Post by Mills Extreme Vehicles on May 5, 2016 14:33:51 GMT
The manual states you must have one but does not say you have to see anything out of it.
Post by p5curly on May 5, 2016 17:05:49 GMT
Ahh I see
Post by martinw on May 5, 2016 17:15:48 GMT
....in fact it makes a nice aid to seeing how your passenger is feeling  . Mine is aligned so I can see the whites of Linda's eyes Martin
Post by james13009 on May 6, 2016 12:06:11 GMT
Centre mirror is there (and yes it is useless) will upload some pictures later. I'm also blocking up the rear holes. And moving the side lights forward
Post by james13009 on May 6, 2016 12:08:04 GMT
Do need anything to prevent me over filling the fuel tank?
Post by Mills Extreme Vehicles on May 6, 2016 15:52:58 GMT
you don't need an overflow control but if it is over filled it must not enter the foot well. Looks like your headlights will need to be much higher for the test
Post by p5curly on Aug 30, 2016 20:12:42 GMT
I take it that it has passed Iva now
Post by skyquake on Aug 30, 2016 21:49:25 GMT
Apologies for the hijack, but I'd like to go into this thing with the interior mirror in a bit more detail. I've seen it written in several places on this forum that the interior mirror IS required for IVA, but unless I'm misunderstanding something, it is not a firm requirement of the inspection manual.
Item 2 of Section 08 of the manual states "2. An interior mirror must be fitted, (see note 3)" which would seem to be fairly definitive. However, note 3 removes the need for the mirror, if it offers no rearwards vision. "Note 3: The interior mirror must be positioned as far as is practical to afford the best possible view to the rear, if the interior rear-view mirror does not provide any rearward vision its presence shall not be required."
Vans for example, do not require an interior rear view mirror, if you can't see out through the back, as is logical. Obviously with kit cars, it's a lot less clear cut, as the IVA manual offers no further clarification on the definition of 'no rearward vision.' In my mind, if the only thing visible in the mirror is the engine cover and rear wing, then it offers no usable rearwards vision. Therefore, as long as there is no practical way of positioning it to offer any usable rearwards vision, you should have a very good case that you do not require one, surely?
Post by mawdo81 on Aug 31, 2016 11:50:11 GMT
Yes, the argument often comes back that you'd need one to prove that to be the case. I intend to take the old donor one to position temporarily and have a grown up discussion with the inspector, once they can see what would/would not be visible.
