Post by James on Nov 16, 2014 14:57:11 GMT
Excellent news on your test marmot0. Well done. I hope we do as well tomorrow. Let's compare test centres! Best, James (DeBoRah)
Post by marmot0 on Nov 16, 2014 17:43:03 GMT
Good luck, from your thread it looks like it should go through with no issues, cheers
Post by marmot0 on Nov 23, 2014 16:56:33 GMT
Make sure you order your DVLA forms well in advance, mine took an age to arrive, not such an issue in Winter but would be a shame if you pass in the summer. Cheers
Post by jimmypatch on Nov 24, 2014 13:41:19 GMT
Well done on the pass
Post by marmot0 on Nov 25, 2014 6:56:41 GMT
Thanks. The credit should really go to Stuart and mazda though
Post by jimmypatch on Nov 25, 2014 21:10:51 GMT
How long has this build taken you?
Post by marmot0 on Nov 25, 2014 21:13:41 GMT
Hi I started stripping the donor in March, cheers
Post by p5curly on Nov 26, 2014 19:04:30 GMT
Well done with the pass .we have wrap around harnesses in our mevster and the iva man never questioned ours seems every examiner has a different opinion
Post by marmot0 on Nov 26, 2014 19:26:58 GMT
Hi, they were not keen on the lateral movement, luckily i had the old fuel filler hose a saw and some large jubilee clips but I did have to show sections from the MSA blue look so a close one there.
Post by marmot0 on Nov 26, 2014 19:28:43 GMT
Post by R2S on Nov 26, 2014 22:04:40 GMT
Post by gwnwar on Nov 27, 2014 0:48:18 GMT
Those 16" you listed are 5 lug wheels..you would need an adapter plate.. found these specs.for mk3 16" diameter 6.5" wide 55mm offset 67.1mm bore centre hole 114.3mm pcd 5 bolt..
Do a Google search for 15" 4x100 lug steel wheel and 16" many cars have them..
Also found this on ebay USA eBay item number: 191407313812 4 for $200.00 check hubs sizes too.
Post by marmot0 on Nov 27, 2014 11:47:25 GMT
Post by marmot0 on Dec 4, 2014 13:19:48 GMT
Hi, just fitted the wire wheels, I think they are a bit heavy for a track focused car so I have decided to sell them. They are 15 inch 7j and will come with 4 good khumo ecsta tyres as shown in the picture. They look presentable but are far from mint so make me an offer if you are interested. Thanks
Post by spudman on Dec 4, 2014 23:53:27 GMT
Howdy, I'm interested if they're still available, but I can't see how to send you a PM. Drop me an email on speed_david "at" hotmail.com if they're not taken yet, cheers
