Post by marmot0 on Sept 26, 2014 20:43:34 GMT
Hi, has anyone got an mx 5 steering wheel kicking about that they no longer need. Just need one for the IVA. Many thanks
Post by marmot0 on Sept 26, 2014 21:55:41 GMT
Front end taking shape with headlights and covers fitted. Found the best way to fit these was: get Stuart to trace out the outline from the cut outs from the mould then rough cut to shape with the dremel and then chip away with the bench grinder. Waiting to hear back from the Iva station regarding dates
Post by R2S on Sept 27, 2014 8:19:47 GMT
Which way did you go with the exhaust in the end?
Post by marmot0 on Sept 27, 2014 9:01:28 GMT
I am keeping the standard exhaust for the Iva as I know it should pass, I have simply chopped the tail pipe off close to the box and rotated it downward to clear the body work , after Iva I will by a standard stainless exhaust chop the tail off and weld a new one on to exit behind the drivers rear wheel arch
Post by jimmypatch on Oct 3, 2014 8:22:50 GMT
Im going side exit from the get go, i have read the iva manual and as long as you have a cat, a silencer and its under 99db then its all good.
Post by nigel on Oct 3, 2014 8:36:21 GMT
Im going side exit from the get go, i have read the iva manual and as long as you have a cat, a silencer and its under 99db then its all good. Just remember no sharp edges, 2.5mm radius rule on the end of tail pipe etc Nigel
Post by jimmypatch on Oct 3, 2014 10:36:04 GMT
i beleve that exhausts are exempt the 2.5mm rule, they just need a rounded edge
Post by marmot0 on Oct 3, 2014 14:18:50 GMT
I decided against this in the end as I think the exhaust will have to come into the passenger foot well, I am also fitting a turbo so this will cause a headache , also a bit worried about temps in the side pods I would think you might have to chop some big holes to let the heat out. Cheers
Post by jimmypatch on Oct 3, 2014 17:59:13 GMT
I agree with the holes, I'm going to cut the body to show off the exhaust as per DBR1. Will your car pass emissions with a turbo fitted?
Post by marmot0 on Oct 3, 2014 18:42:20 GMT
I will turbo it once it is one the road. Just waiting to hear from VOSA when the test is
Post by marmot0 on Oct 3, 2014 18:50:29 GMT
If you take a look at this clip
and go to around 2:35 you will see he has brought his exhaust out behind the rear wheel which is what I will be doing
Post by marmot0 on Oct 4, 2014 16:43:44 GMT
Hi looking for one MK1 MX5 seat runners, none on ebay so would be great if someone has one kicking around they would be willing to sell. Thanks
Post by mawdo81 on Oct 4, 2014 17:07:33 GMT
Try posting in the wanted section, it might get noticed by someone who isn't following your thread. Good luck, I could do you a focus mk1 runner ;-)
Post by marmot0 on Oct 9, 2014 17:12:01 GMT
Hi, do we reckon leather bonnet straps would pass IVA if the buckle was covered in some way. Thanks
Post by marmot0 on Oct 9, 2014 19:00:30 GMT
Interior pretty much finished for IVA, I can't decide whether to panel over the hand brake mech but Stuart passed without. I ended up using the MX5 seat runners in the end, bit of a tight squeeze but got there in the end.
