Post by marmot0 on Mar 24, 2016 7:15:04 GMT
Thanks, I highly recommend the car, it also drives as good as it looks !!
Post by marmot0 on Mar 25, 2016 19:36:44 GMT
The car is now almost ready to go back on the road!!, I have completed the wrap around windscreen, paneling and also fancied a change so made a curved transmission tunnel. Hopefully if the weather holds up tomorrow I will get the bonnet fixed properly and ake a start on the tonneau cover
trident
Improvise, Adapt and Overcome
Post by trident on Mar 25, 2016 20:00:35 GMT
Very nice. Tunnel looks very good and very in keeping with the rest of the car. Well done.. Will it be at Stoneleigh?
Post by gwnwar on Mar 26, 2016 0:39:36 GMT
Like the tunnel looks real period built. How about some wooden floor mat/inserts like period..
Post by marmot0 on Mar 26, 2016 7:48:45 GMT
Hi. If the weather looks good I will be at stonelleigh, and yes marine ply floor boards are in the list it was at the bottom but almost there now. Thanks for the comments
Post by R2S on Mar 26, 2016 17:51:58 GMT
Top job, the round tunnel looks so much better, and the full panelling looks period, you can come and do mine if you want?
Post by mawdo81 on Mar 26, 2016 18:14:48 GMT
How did you do the tunnel? Thinking of something similar in alupanel
Post by marmot0 on Mar 26, 2016 21:19:26 GMT
With the paneling I made templates out of lining paper, then transfered the template to 0.9mm aircraft aluminium, I then bent everything freehand until it looked right. Cheers
Post by marmot0 on Apr 2, 2016 15:59:24 GMT
Wheels again, thinking of converting my hubs to splined using these adapters: shop.mwsint.com/product_details.asp?id=415I know they do an MX5 wheel but they are very expensive compared to the knock on wheels, having been out today I think 170/70/15 is just about the right tyre for gearing and ride quality.
Post by R2S on Apr 2, 2016 20:44:11 GMT
Hindsight is a wonderful thing but this is the route I wish Id gone as the 7j wires I bought with the kit are simply too wide for period width tyres, highly likely i'll be using 205 70 15s to suit the rim width rather than aesthetics.
Post by R2S on Apr 6, 2016 17:37:51 GMT
Post by bigpaul on Apr 6, 2016 17:47:57 GMT
Not sure they would, if I recall correctly (sure I read it somewhere) MX5 hub is 100mm
Post by mawdo81 on Apr 6, 2016 17:55:30 GMT
That's right, mx5 PCD is 100mm although you can get adapter stretch space the wheels out. May work depending on the desired offset.
Post by marmot0 on Jun 3, 2016 20:36:15 GMT
All set for the London to Brighton classic and sports car run this weekend, weather looks good too
Post by marmot0 on Feb 3, 2017 19:15:29 GMT
Time to start thinking about the next event which will be Goodwood members meeting, service items ordered ready for the new season:
