Post by p5curly on Sept 4, 2014 17:18:28 GMT
Today's puzzle is heater wiring I chucked my heater assembly away when I had a clear out but now have no clue how to wire them up I have 2 cab heaters and a on / off switch how do I wire them ?
Sent from my iPhone using Tapatalk
Post by gwnwar on Sept 6, 2014 5:04:42 GMT
Are they one temp heating coils and how many speed blower.. I believe you should have an empty space in your engine fuse box.. Got power from there with a good fuse.. what size fuse does the make say to use..how many AMPs do they draw..You can wire the hot to the motors/coil if only one speed with switch heavy duty.. and ground other side of motors/coils..If you have multi speed you will want the ground to control speeds through resistors. Do you have a wire print out and your old blower switch and resistor pack..I am sure someone on here will have the parts if you don't..
Post by p5curly on Sept 6, 2014 7:56:36 GMT
I bought the same heaters that Stuart fitted in the demo mevster I am going to look at the fuse box today
Post by mrjingles705 on Sept 6, 2014 22:00:25 GMT
Yours was a MK2 donor, right? Mines a MK1, I can see differences in the wiring diagrams.... if you want I can ping the diagram across?
Post by p5curly on Sept 7, 2014 15:58:44 GMT
Ours was a late mk1 1997 no abs or airbags so i have managed to fit the heaters now so it looks like I only have to fit original crappy steering wheel and get the horn to come back to life
Post by p5curly on Oct 18, 2014 10:12:34 GMT
Ok a bit of a update on the build ? not much has happened for a while as we are waiting for a test date from DVLA so the MeV has been put to bed for a while so I can tidy up my messy shed
Post by freshp5 on Oct 25, 2014 22:15:21 GMT
Post by mrjingles705 on Oct 25, 2014 22:42:24 GMT
Good luck!
Post by andybaird on Oct 26, 2014 9:37:01 GMT
Good luck on Friday
Post by p5curly on Oct 26, 2014 11:33:23 GMT
Thanks we are doing last prep on the car today just topping up fuel and hire trailer booked
Post by martinw on Oct 30, 2014 18:54:31 GMT
Good luck for the IVA. Bet Jamie is excited too!! Martin
Post by mrjingles705 on Oct 31, 2014 19:11:57 GMT
How did it go?
Post by p5curly on Oct 31, 2014 19:18:24 GMT
Ok so here goes we failed our iva but on minor issues and the examiner explained the faults to us and where happy with the day .the iva man was very polite and helpful and made our test a very calm relaxed experience .so with our minor fail sheet back to the shed we go
Post by mawdo81 on Oct 31, 2014 19:24:55 GMT
Sorry about that but it doesn't sound too bad? Can you write up the fails? Have you booked a retest yet?
Post by p5curly on Oct 31, 2014 19:50:24 GMT
We plan on doing all the fails before booking the retest as for the fails I will list them in a bit
