Post by casesensitive on Feb 7, 2014 9:08:48 GMT
well you did ok at 400 there then Absolutely, if Omex give it a clean bill of health and a firmware update (and hopefully an ST170 base map) I'll be thrilled, absolute steal at that price, and as you said, if it doesn't work out I can likely sell it for what I paid for it. Shopping around for wiring and ITBs now :-)
Post by casesensitive on Feb 8, 2014 23:50:43 GMT
Picked up a set of GSXR1000 TBs, injectors, wiring for £78 tonight, so modification guide coming up whenever I figure out how to put it all together :-)
Post by casesensitive on Feb 12, 2014 12:05:52 GMT
Omex 600 with loom starting at £495. Not a super-bargain, but with some small mods it'd fit a Zetec, would need a map, but we're starting a map-sharing area on there, if we're let. I bagged a race-spec Omex 600 loom that had been fitted to a Vauxhall there yesterday for £80, absolutely delighted. Going to spend a few hours with a multi-meter and move some around the Omex plug to suit the 710 it's going into, but still far cheaper and less hassle than buying all the plugs and attaching themself. Top tip, set up a couple of searches on Ebay with price limits; I had 3 running for a couple of weeks, 'Omex loom' 'Omex wiring' and 'Omex harness', all < £140. Great way to snag a bargain, and you won't miss anything.
Post by casesensitive on Mar 11, 2014 20:30:18 GMT
Post by Paul (madeye) on Mar 12, 2014 7:16:44 GMT
it has 100k on it, my pal emailed about it
Post by casesensitive on Mar 12, 2014 8:19:19 GMT
it has 100k on it, my pal emailed about it Really? Wow. Looked new, but on closer inspection, it's a paint job, you can make out corrosion around the bolt-holes. I guess that should be clearer in the ad. Sounds like one to walk away from so; not the mileage, but hiding it.
Post by casesensitive on Jun 11, 2015 16:06:36 GMT
GSXR1100 with DTA complete set up an 1hr to go @ £1000 www.ebay.ie/itm/121666825489?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l264988 OIL COOLED!!!! Race Tuned GSXR1100 Competition "Plug and Play" Engine Package! DTA E48EXP Programmable ECU Custom Aluminium Throttle Bodies Polished and Ported head 4-1 Exhaust and Carbon End Can Drive Flange for Ford Prop (Prop available on request) Fuel Pump, Tank and Lines (Tank is steel and rusted, does have huge filter!) AB Performance Chassis Mount Brackets and Bolts Accusump System Fitted (TESTED OK!!!) 12V Battery 5spd Gearbox Low use clutch Exceptionally Low Miles!!! ALL ANCILLARIES - FIT - ADD FUEL - PLUG AND PLAY!!! CAME FROM HILLCLIMBER - BOTTOM END GOOD FOR 500BHP!!! Edit: Sold for £1300+
Post by casesensitive on Jun 12, 2015 7:50:39 GMT
Post by airforceone on Jun 12, 2015 11:56:53 GMT
States that it comes as seen, so no manifold, turbo, gearbox, ecu and loom by the looks of it.
So could end up being a bit pricey to get it going...
Post by casesensitive on Apr 13, 2016 10:59:14 GMT
Post by casesensitive on Apr 13, 2016 14:27:06 GMT
Post by casesensitive on Apr 21, 2016 11:25:20 GMT
260 BHP turbo'd Zetec with Pectel ECU, LSD, Cossie pistons. £3,750 BIN Zetec turbo Cosworth pistons & rods 2100cc 260bhp @ only .9 bar Pectel t2 ecu Stage 3 ported & pollished head Kent cams & vernier pulleys Quafe lsd Quickshift Race fuel system with swirl pot Mounts Also, comes wrapped in a free Fezzer...
