Post by donboy1983 on Jan 9, 2014 23:18:26 GMT
Haha yeah it is a bit tight :-) I managed to start work on the car tonight, only had 3 hours but got a fair amount removed from the car. Was great to be playing with some tools again for change. I did find something I was a bit unsure of tucked underneath the centre console. I'm guessing it's something to do with the alarm / imobilizer but hope some one can advise. apart from that all went to plan :-)
Post by jgilbert on Jan 9, 2014 23:32:00 GMT
Don,
Was thinking back to our early days and a useful tool list.
Apart from the obvious (decent socket set, screw drivers, penetrating oil and big hammer).
A good breaker bar Trolley jack Disc grinder A range of G clamps
Have all been invaluable. Later in the build a Rivnut tool (I brought the MemFast one) Cleco pliers and fasteners are worth there weight in gold.
Post by donboy1983 on Jan 9, 2014 23:40:27 GMT
I do have a good range of tools that I have built up over the years of working as a service engineer. I now work in an office so it was good to get my hands dirty again.
Although I don't have a rivnut tool or cleco pliers so will add them to the shopping list along with blue roll, gloves and a kettle.
Post by gwnwar on Jan 10, 2014 7:09:58 GMT
I would only use 6 point sockets on any rusty bolts/nuts on the underside to keep from rounding off.. 4foot of pipe to lengthen the breaker bar.. Loosen the rear axle center nuts while you still have brakes. Also front hub/axle nuts.. Drain gas left bottom of tank..
Post by kecclest on Jan 10, 2014 11:48:07 GMT
In regards to the hub nuts, I used an Ingersoll Rand W7150 cordless impact and had both rear nuts off in less than 15 seconds. I'm quite happy with my investment in that kit.
Post by Deleted on Jan 10, 2014 22:30:26 GMT
Haha yeah it is a bit tight :-) I managed to start work on the car tonight, only had 3 hours but got a fair amount removed from the car. Was great to be playing with some tools again for change. I did find something I was a bit unsure of tucked underneath the centre console. I'm guessing it's something to do with the alarm / imobilizer but hope some one can advise. apart from that all went to plan :-) Yep I had something very similair in my centre console and it is for the alarm, dont lose it mate
Post by donboy1983 on Jan 12, 2014 19:19:31 GMT
I though it would be to do with the alarm,
No progress on the car this weekend but I did get a bench sorted for the workshop and today we went to the Autosport Show at the NEC and put the deposit down on the Exocet :-)
trident
Improvise, Adapt and Overcome
Post by trident on Jan 12, 2014 20:05:13 GMT
Congrats...Did You get to see one in the flesh and how long until you pick the kit up?
Post by donboy1983 on Jan 12, 2014 20:23:30 GMT
I seen a white one that was a race spec one. I will still take you up on coming to see your work in progress if that's ok. I went for the black option so I can collect next week if I want. I just need to decide on the rear fender type first.
trident
Post by trident on Jan 12, 2014 21:08:43 GMT
Yeah no problem coming down to have a look at mine… when you say black option is that the panels or the chassis that is already powder coated or both?
Post by donboy1983 on Jan 12, 2014 21:21:33 GMT
Just the panels, I will get the chassis powder coated locally once I have finished drilling holes in it and cleaned up any weld splatter that I have read about. Is powder coat the best option? Stuart today said he would use 2 pack paint on the chassis ?
Post by jgilbert on Jan 12, 2014 22:36:10 GMT
I looked into painting the Chassis. Its a difficult job because of the tubular design. Lots of nooks and crannies to get a even coat of paint on. The tubes are a nightmare for runs. Power is electrostatically drawn to the frame, so getting an even coverage is straightforward from what I have read. I believe Welshy painted his chassis, maybe worth contacting him for advice.
Post by Deleted on Jan 13, 2014 21:21:53 GMT
I bought my chassis 2nd hand 'painted' and immediately sent it to be stripped and painted. All the points mentioned so far are 100% on the money. Paint not reaching the nooks and crannys is one thing, primer not making it will give you a car you wll need to move on quite quickly before the paint falls off or rust takes hold....IMHO
Post by donboy1983 on Jan 13, 2014 22:13:48 GMT
Powder coating it is then. I made a start on the dash tonight and managed to remove most of the parts before I had to give up and come home and find a guide on how to do it. www.miata.net/garage/DashRmv_89_93.pdfthis is very helpful and will make the rest of the job tomorrow a whole lot easier.
Post by jgilbert on Jan 13, 2014 22:45:27 GMT
HaHa, Let the fun and late nights begin!!!
