Well it looks about time for an update seen as its been nearly a year since the last post!
So at the end of last year I got hold of a couple of front wing elements from an old small formula car and made myself a small front wing thing.
I also built and installed some shift lights of an F1 type style. They are in the edge of the bonnet facing the driver and can be seen just above the steering wheel. They are a curved line of LED's, the first 8 are blue which start to light up one by one as you get to the top end of the rev range and then there are 4 red ones that come on together when its time to change up a gear. I've just realised I haven't got any photos of them! I'll do a little video of them once the car is running again.
So that was the end of summer last year.
Since then I've done some maintenance and mods;
1) Change the drive shaft oil seals in the diff. These were weeping a bit of oil, one more than the other
2) Modify the exhaust system. I've put the cat back in to try to quieten it down a bit
3) Fabricate and fit a brace bar to the front suspension points as per the important build guidance notes
4) Fit a set of bike throttle bodies
5) Change the ECU to run the new throttle bodies
So the oil seals, exhaust and brace bar were pretty straight forward. I made the brace bar out of alloy tube, 28.6mm (1 1/8") diameter by 3.3mm thick wall (10swg), I squashed the ends flat in a vice (using lots of heat so not to crack the edges) and then rounded the ends off, drilled holes and fitted it to the wishbone mounts using longer bolts.
The throttle bodies have been a whole different adventure! I had a plan, but as these things do, it changed.
I was on a tight budget to get the throttle body conversion done so was delighted to find a set of already re-spaced 40mm bike throttle bodies on ebay at a good price (£72) and what made them really good was that they had a zetec manifold with them too! When they arrived I was less impressed, the throttle bodies were 38mm not 40mm, they had been re-spaced with some random bolts, no spacers in between so the only thing holding them apart was the silicon hoses attaching them to the manifold, the whole assembly flexed! And the manifold was glued together! yes that's right, the tubes coming off the flange plate were glued in, not welded. So they went back in a hurry! Note to self (again!) if something looks too good to be true then it probably is!
I went back on the prowl for some throttle bodies and ended up with some Hayabusa bodies with injectors and TPS for £135.
I re-spaced them using some alloy tube for spacer and longer threaded rod. The fuel rail on the hayabusa throttle bodies are made up of plastic pieces where the injectors attach and alloy joining pieces in between. I planned on making new longer alloy joining pieces on the lathe and them joining into 2 of them for the fuel line connections. the pic below shows the re-spaced bodies and the new joining pieces.
I managed to manipulate (bend) the mechanism that connects the butterfly valves together and get them all working together.
Next was an ECU, as I'm an electronics bod I decided to go for a Megasquirt DIY system, I've heard good things about them and the thought of putting it together didn't faze me. So one was acquired and put on the shelf while we got Xmas and new year out of the way.
Over Xmas something good happened, my mother in law decided to buy a new car. Why is this good you may ask? Well, the car she had already was an 05 plate Mini Cooper Works with only 15,000 miles on it. She had had it from new and it had been looked after. She was changing it for a new Fiat 500 and the dealership had offered her next to nothing for the Mini (as they do). So she asked me if I want to buy it for the same price as the dealership had offered. I took it for a spin and found it was much more fun than the diesel Mazda 3 I was driving at the time, so we did the deal. Now the other side to this is that the Mazda I had was also low mileage and newer than the Mini and I was able to sell it for more than I paid for the Mini, so the extra cash went into my kit car fund! (well some went into the hole that was left from the wife's Xmas presents!).
For the ECU I had planned on using the Megasquirt to run the show but keep the standard ECU (piggy backed) to run the VVT, I had looked into it and thought (by the way of some electronics trickery) I could make it work. However with new funds available I started looking at other options. This led me to the Motorsports Electronics ME221 ECU, the same one Casesesitive is using in his build. It costs more but runs the VVT properly as well, they also come with wiring looms.
The new funds also allowed for some more new bit to be bought;
Alloy manifold to suit re-spaced throttle bodies, velocity stacks (trumpets) and air filter all from DanST engineering.
So it's starting to come together. Since the above pic I have fitted and wired in the ECU, modified the fuel tank to have a return line, fabricated and fitted a bracket for the throttle bodies and knackered the new longer joining pieces for the fuel rail (another story ). I've ordered a new Omex fuel rail now, just waiting for it to be delivered. Once the fuel rail arrives I will be attempting to start up the engine, videos to follow.....
