alr
Junior
new to the board. thinking about building the mevster. need to know more
Post by alr on Jul 7, 2014 22:03:41 GMT
got the left side rear finally completed. Only had 1 major issue. The bolt at the bottom of the shock stripped in the nut. I had to cut the bolt with a multi tool. The nut was shot as well. I bought a new bolt from Mazda and a lug nut fit.
alr
Junior
Post by alr on Jul 26, 2014 19:07:32 GMT
Finally finshed the rear end today. It's been since the beginning of June to the end of July to take it apart, clean it up, paint it, rebuild the brake calipers, change the seals in the hub and put it back together. next up, clean and paint the PPF, get a engine hosit and pull the transmission, pull the clutch and start on the front end.
alr
Junior
Post by alr on Jul 28, 2014 23:23:25 GMT
I knew the car had clutch trouble when I got it from my brother-in-law, but I didn't expect this. I thought all along it was going to be a bad slave, not the pressure plate
alr
Junior
Post by alr on Aug 5, 2014 23:58:29 GMT
Transmission is all cleaned up and ready to go
alr
Junior
Post by alr on Aug 5, 2014 23:59:51 GMT
pulled the motor off today and found a broken motor mount. Ready to start on the front end
alr
Junior
Post by alr on Sept 5, 2014 21:30:13 GMT
OK, I need some help here.
I am trying to get the power steering rack apart by following the flying miata instructions. I have everything apart as listed but I can't pull the rack out. It sounds like its hitting on something inside.
Has anyone done this yet and experienced this type of issue? Any suggestions?
Ron
Post by mrjingles705 on Sept 6, 2014 7:46:07 GMT
Can you post some pictures?
There shouldn't be anything holding it in once you've removed the rod ends, the pinion gear and the stop ring.
alr
Junior
Post by alr on Sept 8, 2014 1:10:19 GMT
Ok, I just needed to tap a few times with my rubber mallet due To some rust and age. After all, the car was a 1991
alr
Junior
Post by alr on Oct 4, 2014 16:46:32 GMT
Finally got the front end finished
alr
Junior
Post by alr on Oct 4, 2014 16:48:08 GMT
Now its time to move on to the motor, get it pressured washed and moved into the garage
alr
Junior
Post by alr on Nov 11, 2014 22:21:13 GMT
Got the exhaust finished, should help with my cold air intake
Post by gwnwar on Nov 13, 2014 1:23:07 GMT
Are you sure you want to wrap the exhaust tubes..They will rust out easier that way..
Post by mawdo81 on Nov 13, 2014 6:54:17 GMT
Why is that, and would the risk be the same in a sonic?
Post by mrjingles705 on Nov 13, 2014 7:29:51 GMT
Exhaust wrap isn't waterproof - generally, it actually holds water - so it's like strapping a wet rag to any piece of steel, ultimately you'll get rust. And probably more rust than you'd get otherwise.
If you use high-temp paint on the exhaust first *then* wrap it once that dries it mitigates the problem quite a bit....
Post by mrjingles705 on Nov 13, 2014 7:36:35 GMT
Should add - DO NOT use the spray-on silicon sealer stuff for the wrap; it sounds like a good idea but it causes more problems than it solves.
