Post by media116 on Nov 30, 2013 18:04:50 GMT
Hi All,
My chain has stretched quite significantly and, before I re-tension it, I thought I'd better check the degree of play that's desirable on a TR1ke. Is the standard bike requirement of 1-1.25in appropriate, or should I be aiming for a different figure?
Regards,
Chris
Post by andy7b on Nov 30, 2013 19:06:49 GMT
I go for the bike setting so around an inch, if your on a new chain it will stretch quite a bit for the first 1000 miles then settle down. Andy
Post by media116 on Nov 30, 2013 20:22:19 GMT
Many thanks Andy. Incidentally, which sort of chain lubricant do you find works best?
Post by andy7b on Dec 1, 2013 20:12:02 GMT
I use Worth professional lube but it doesn't matter who's you use really just a good quality one, I do tend to go for stuff that doesn't have any colour but I'm a bit anal on the cleaning :-)
