Post by lemans75 on Oct 2, 2019 15:40:17 GMT
I never had much luck with photobucket so I found an alternative that I find works nicely for anyone using google photos. (I have an android phone that uploads all photos taken to google photos) Steps: - On your computer, go to photos.google.com- Select a photo - Click on the "Share" option - Click on the "Create link" option and copy that short link - Go to: ctrlq.org/google/photos/- Paste the link in the box and hit "Generate Code" - Give it a couple of seconds and the page will scroll down and show you the "Direct Link (URL)" - Copy that and paste it in the URL box in the image embedder on this forum and the image should pop right up. Sounds complicated but it's really only 2 steps
Post by R2S on Oct 2, 2019 21:36:10 GMT
Standard airbox fitment showing clearance to exhaust View from underneath showing fixings As viewed from front of wheel arch, will need pipe from intake to front of Replicar body Also tidied up under bonnet fusebox and emissions
Post by tojeiro on Oct 3, 2019 7:19:30 GMT
Can’t see the latest photos. Maybe needs to be shared as even clicking where the photo should be just shows a negative (-) sign. by -Tojeiro 74-
Post by ancsportscars on Oct 3, 2019 7:36:46 GMT
Odd. They were there last night.
Post by R2S on Oct 3, 2019 10:59:34 GMT
Yep just had a look without signing in and no photos, will have another go at uploading.
Ok re inserted photos above, will check again tomorrow to see if they are still there..
Ordered parts last night for start on lights and electrical connectors and install of cut off and battery wiring to rear of passenger seat before taking plunge on a new battery.
Post by R2S on Oct 3, 2019 11:17:18 GMT
I never had much luck with photobucket so I found an alternative that I find works nicely for anyone using google photos. (I have an android phone that uploads all photos taken to google photos) Steps: - On your computer, go to photos.google.com- Select a photo - Click on the "Share" option - Click on the "Create link" option and copy that short link - Go to: ctrlq.org/google/photos/- Paste the link in the box and hit "Generate Code" - Give it a couple of seconds and the page will scroll down and show you the "Direct Link (URL)" - Copy that and paste it in the URL box in the image embedder on this forum and the image should pop right up. Sounds complicated but it's really only 2 steps I dont get the "Create Link" in share option.
Post by lemans75 on Oct 3, 2019 12:27:29 GMT
That's strange, you should see something like this:
Post by R2S on Oct 3, 2019 15:45:14 GMT
Nope I'll have another look see if I can work out as i note pictures have started disappearing again.
Post by lemans75 on Oct 3, 2019 17:24:58 GMT
I had the same thing happen when I embedded google photos with the short link. Using ctrlq.org/google/photos/ to generate a "permalink" was the solution that worked for me.
Post by R2S on Oct 3, 2019 20:59:38 GMT
I have it sorted just need a little time to upload, link and then go back to individual photos to load to forum.
Post by R2S on Oct 6, 2019 15:49:02 GMT
On to some more minor jobs today. Cut off fitted, think most people place here Over flow bottle fitted (actually from a British classic) Short term solution for harness upper fixing for IVA First time spinners and wheels have been together in FIVE YEARS! Temporary install of donor seats to test driving position My own tunnel and transmission section design
Post by tojeiro on Oct 8, 2019 10:27:55 GMT
Will you get the body on with those seatbelt mounts? I had to cut down the tube by 1/2” to get enough clearance.
It maybe depends a little on the position of the body.
Post by R2S on Oct 8, 2019 18:08:57 GMT
Trial fit of body previously cleared the posts
Post by R2S on Oct 8, 2019 18:13:49 GMT
Should add this is where front of engine sits with rear bulkhead as in previous photo
Post by R2S on Aug 3, 2020 13:56:30 GMT
Well at long last I am back in the workshop! Ali panels all now complete, remember this car has no doors so internal horizontal panel runs full length. The inclined panels are only installed temporarily as they will need shaping on the outer edge to match the body inner face. Aluminium sheet arrived for top of dash last thing Friday so this weeks job will be to install. Had originally planned to have looms coming through this horizontal panel but now looking to pass through from firewall (main loom may prove a challenge on drivers side). Trim rings have arrived for the dash, using MX5 plug and play set behind the dash, and undecided whether to have aluminium faced dash or whether to paint black. Finished off air box changed air intake to face forward. Will now be able to connect with pipe to draw air from nose. Combined reversing/fog lights sourced from cbs, will place one either side under rear lamps now starting to pull together electrics for lights etc.
