Post by drbrian on Mar 10, 2014 0:38:52 GMT
Hello Everyone I finally got all the suspension put on after 5 months, I am sure I did somethings wrong, If you see anything that is wrong please mention it! Thanks Brian Above is drivers side front Passenger side front Passenger side rear Below the car is used to store stuff while I work on the suspension
Post by drbrian on Mar 15, 2014 23:36:53 GMT
Post by drbrian on Mar 20, 2014 21:46:26 GMT
I found a great place to provide wheel hub spacers that are exact mates for the 2002 ford focus hubs. The website is below and the fellow I spoke with is Jason. My understanding is they custom machine these to order and very reasonable at $65 a piece. The specs are as follows. 4X108 to 4x108mm with 50.8mm thick hubs. The inner diameter of the spacer is 63.78mm based on the focus 2002 hubs and will fit concentric so to avoid wobbling. adaptitusa.com/4x108to4x108wheeladapter.aspxAlso I love this pictures, My friend Brett will buy a Mini soon and we will mirror this images
Post by drbrian on Mar 21, 2014 18:52:58 GMT
Painted Steel Rims Blue Dupli-color Engine Enamel I will use these till I feel like coughing up the money for rims and new tires, no more brake dust on me nice pants.
Post by drbrian on Mar 21, 2014 18:57:15 GMT
Re manufactured Rear SVT focus Brakes
Ok update I ordered the wrong rear calipers these were for the regular ford focus, The correct ones from rock auto are as follows
Part Number Part Type Price EA Core EA Quantity Total 2002 FORD FOCUS 2.0L L4 DOHC A-1 CARDONE 18B4822A Caliper $ 59.79 $ 49.50 1 $ 109.29 A-1 CARDONE 18B4823A Caliper $ 52.79 $ 55.00 1 $ 107.79
I will post pics as soon as I get them.
Thanks Brian
Post by andybaird on Mar 26, 2014 8:53:26 GMT
Hi Brian
I have got the standard rear discs for the Ford Focus. Not sure of the size.
Cheers Andy
Post by drbrian on Mar 30, 2014 14:55:42 GMT
Got some work done this weekend, I had an half day on Friday which helps a lot. Sides panels, steering, and started on brakes. Brakes lines are next. I have been postponing buying brake pedals till absolutely necessary, it might be coming up on that time.
Post by drbrian on Apr 5, 2014 15:09:34 GMT
Here are the brake calipers from the Rear SVT I am going to go fit it on the car later today. Part Number Part Type Price EA Core EA Quantity Total 2002 FORD FOCUS 2.0L L4 DOHC A-1 CARDONE 18B4822A Caliper $ 59.79 $ 49.50 1 $ 109.29 A-1 CARDONE 18B4823A Caliper $ 52.79 $ 55.00 1 $ 107.79
Post by airforceone on Apr 5, 2014 18:57:36 GMT
If you have any issues with the rear calipers they are exactly the same as the standard Focus model except the carrier is different so any spares should be easy and cheap to buy.
I have them on the rear of my rocket and they seem to be performing well.
Post by drbrian on Apr 6, 2014 19:28:52 GMT
This one seems to fit, I had the wrong caliper for the normal 9.96" rotor but I bought the right one. The problem I have now is I over torque the parking break leaver and the piston moved in, now I have to figure out how to back out the piston. In the instruction it said specifically not to put pressure on the parking brake. Thanks Brian I put one on with the pads and it seems to fit well. The other
Post by mawdo81 on Apr 6, 2014 21:04:51 GMT
Get your self a caliper rewind tool, I picked one up on eBay for less than £20 as had to do the brakes on my regular car as well as working on the donor.
Post by drbrian on Apr 9, 2014 2:10:30 GMT
Excellent I order the caliper (Dice) and they should come in tomorrow. Thanks Brian
Post by drbrian on Apr 9, 2014 3:47:35 GMT
Here is Dave headers coated with ceramic , they look great can take the heat and will not rust inside or out. Sorting out the brake calipers
Post by mawdo81 on Apr 9, 2014 13:29:53 GMT
Did you coat the headers inside as well as out then?
Post by minuit on Apr 9, 2014 21:05:21 GMT
Where did you get the headers coated? How much did you pay? I couldn't find any local places could only find Jet Hot, Swain Tech and Nitroplate.
Seems a bit of a pain to ship them out, get them back, etc
