Post by bluecob99 on Sept 15, 2013 4:54:35 GMT
Hi there, first like to say finally got the kit, yesssss, been a wait, secondly just had it Powdercoated looks great, thirdly went to install engine with my little boys and noticed to mounts for the engine on the frame are far to long??? Engine is 2000 model which top mounting points are around 400mm on the engine , on frame 330mm is it me or has the factory cocked up now it's been freshly Powdercoated, they supplied the engine by the way. Any advice would be great. Many thanks
Post by roadtrackrace on Sept 15, 2013 9:14:16 GMT
Could you elaborate a little. We produce 2 versions of the tR1ke chassis, one for 1998 to 2003 R1's and one for 2004 to 2006 R1's.
The kits supplied to Oz were for the 2004 to 2006 powerplants.
RTR
Post by bluecob99 on Sept 15, 2013 12:59:11 GMT
Thanks for your reply RTR, as mentioned distances on top mount of chassis are 330mm, my engine is 2000 model which distances are 400mm from either side, bolt to bolt, does this mean engine mounts need cutting back and re- welding, do tell me the other 2 engine mounts will be the same?
