Post by pandypops on Jul 21, 2014 22:45:27 GMT
Can someone with a fully built Atomic do me a favour and post pictures of the clutch and accelerator cable fixings at both pedal and motor ends and the routing as I need to source cables and want to make sure I get the right ones! Thanks Tom Hi Tom, Did you get the pictures you need? I look after Nelson's Atomic and currently have it partially dismantled, so can get you all the pics you need. James.
Post by tom74 on Jul 22, 2014 12:19:39 GMT
Hi James,
I did get some but I think Nelson's car is more similar to mine so if you could take some pics of the connection and routing of the throttle and clutch cables for me that would be a great help.
Thanks Tom
Post by pandypops on Jul 24, 2014 23:00:29 GMT
Throttle connection at pedal: Another view: The throttle cable route, laid over the frame: Connection to engine with cover lifted: Connection to engine with cover resting in normal position:
Post by pandypops on Jul 24, 2014 23:06:00 GMT
Clutch connection at pedal from above: Connection at pedal viewed from seat: Clutch cable route viewed from above, running along the top of the lower frame: Cable run viewed from the side: I would have had to lift the car to show the connection to the engine, but I'm sure you know what's happening there! I hope the pictures are of some help. Let me know if you need any more.
Post by tom74 on Jul 25, 2014 11:58:11 GMT
Brilliant, thanks!
That's just the angles I was looking for, now to do some measuring and make up some brackets...
Post by tom74 on Aug 10, 2014 20:06:36 GMT
Slow going, got fuel pump in today, so at least can measure now for hose length. On the plus side I have been googling the part numbers for the 2007 R1 bits I have and finding items shared with all sorts of other bikes and even jetskis, makes the ebay searches wider and ultimately cheaper.
Got to get the exhaust cut/re-routed too, hopefully without any drama!
Post by tom74 on Nov 19, 2014 9:13:58 GMT
Got the exhaust mocked up yesterday to measure up for bracket making, looks a bit tight at the manifold but assume that once on properly that should be fine, nuts only finger tight and no gaskets as yet. Staring to look almost finished!
