Post by birubhai on May 19, 2016 21:38:58 GMT
HI, sorry haven't had chance to introduce. I bought an Exo R some 3 months back in UK, but as it was not being used for past 1 year engine and brakes were in bad shape so after some engineering, fabrication, brake upgrades etc the trike is up and running. Re tyres, it was running motorcycle/scooter spec tyres and bump steer at 60 MPH onwards was scary. I did take it to 85MPH but it was really scary. I am running now 125/80 front and 145/60 rear as car tyres and almost no bump steer. It is a must to be safe and steering feel is planted when driving.
Now looking for some formula 1 types monotubes. Not sure if worth spending as much on it but strongly leaning towards it. Have done dyno and played with carbs, need more to fettle with engine.
Will keep you posted.
Best
Babr
Post by edvb on May 25, 2016 17:42:17 GMT
Hi Babr
Welcome to the forum.
If you need anything just post it or PM me.
Good luck with the Eco Exo R you purchased recently.
Edward
Post by laube on Nov 30, 2016 10:06:15 GMT
Hi Edward,
What a perfect end result on your eco exo r, read trough the details and they are quite supportive for my current eco exo r build.
Greetings,
Iwan
Post by edvb on Dec 3, 2016 14:12:27 GMT
Hi Iwan
Great to have you in the forum. Thanks for the kind words.
Hopefully some of what I posted will help with your build.
Edward
Post by fuoriserie on Dec 21, 2016 9:51:02 GMT
Cool looking design update of the Eco-Exo....
Post by edvb on Dec 21, 2016 15:16:08 GMT
Thanks Italo
It has been a great and reliable vehicle for me. I cannot wait till Spring to be on the road again.
Edward
Post by fuoriserie on Jan 17, 2017 13:32:21 GMT
Thanks Italo It has been a great and reliable vehicle for me. I cannot wait till Spring to be on the road again. Edward Hi Edward, what type of hubs did you use for the new suspension set-up ? Italo
Post by edvb on Jan 17, 2017 13:51:11 GMT
Hi fuoriserie
Are you asking about the rims? They are stock 2005 front Burgman 400 rims.
Edward
Post by fuoriserie on Jan 18, 2017 21:41:11 GMT
Hi fuoriserie Are you asking about the rims? They are stock 2005 front Burgman 400 rims. Edward My mistake.... I should have said, spindles.
Post by edvb on Jan 18, 2017 23:35:25 GMT
Roger got some spindles from a Honda Goldwing that were solid and used his lathe to turn the end down a bit. They fit the Stock rims perfectly and not being hollow increases the load and safety a bit.
Edward
Post by fuoriserie on Jan 19, 2017 16:30:09 GMT
Roger got some spindles from a Honda Goldwing that were solid and used his lathe to turn the end down a bit. They fit the Stock rims perfectly and not being hollow increases the load and safety a bit. Edward Thank you for the info...
Post by roger32849 on Jan 19, 2017 20:01:41 GMT
The spindles/axles were from a 1980 - 1983 Honda Goldwing GL1100, and yes they needed to be turned down on a lathe. The actual diameter is perfect, but to increase the use able length the rather long head was turned down by about a lineral inch.
Post by fuoriserie on Jan 31, 2017 20:41:03 GMT
The spindles/axles were from a 1980 - 1983 Honda Goldwing GL1100, and yes they needed to be turned down on a lathe. The actual diameter is perfect, but to increase the use able length the rather long head was turned down by about a lineral inch. Thank you for the info Roger ....
Post by roger32849 on Jan 31, 2017 20:55:08 GMT
Fuoriserie: just a heads up.... the axles i used from the 80-83 GL1100 were front axles. Use the nuts as well. You can cut them down and they add a nice look.
Post by Stiggy on Feb 1, 2017 10:20:30 GMT
Love the pin stripping, a real class act. I wrote a piece for Kit Car magazine re vinyl wrapping and remember mentioning the go faster stripes on a famous Gran Tourino. To wrap or not to wrap770.pdf (1.05 MB)
