stubbers
Exocet Number 306
Post by stubbers on Jan 29, 2013 9:48:10 GMT
Ahh okay, is your photobucket set to private?? If you just post your photobucket account link i will see if i can view it. (mine for example s275.beta.photobucket.com/user/Richard_Stubley/library/Exocet this is just by copying the url when you are in your album on photobucket) It seems to be a photobucket issue not a pro boards issue Rich
Post by marshabusa on Jan 29, 2013 9:56:17 GMT
stubbers
Exocet Number 306
Post by stubbers on Jan 29, 2013 10:23:28 GMT
Okay I've just tried uploading like I do normally and it didn't work, so it's definitely not you. Noticed the pic I was trying was uploaded via the iPhone app, could you try uploading one from your pc and see how that goes??
Rich
Post by marshabusa on Jan 29, 2013 10:26:50 GMT
Post by marshabusa on Jan 29, 2013 10:27:56 GMT
Ah ha, right I'll try it all again, Thanks for the help here Rich, am new to this photo bucket and forum thingie ha ha
stubbers
Exocet Number 306
Post by stubbers on Jan 29, 2013 10:33:34 GMT
Well I can see that pic you've put up just Rich
Post by marshabusa on Jan 29, 2013 10:39:28 GMT
Post by marshabusa on Jan 29, 2013 10:41:05 GMT
Now we're getting somewhere! ;D
stubbers
Exocet Number 306
Post by stubbers on Jan 29, 2013 10:43:19 GMT
If only posting pictures was as easy as building cars Rich
Post by testarossa on Jan 29, 2013 21:57:28 GMT
Finally the first Mevabusa build thread (and finally with pictures).
Definitely gonna follow this one, good luck with your build!
Post by Deleted on Jan 29, 2013 23:25:00 GMT
Hey Dean,
Good to see you on here mate
Looking forward to seeing the build progress
Mark
Sent from my GT-I9300 using proboards
Post by marshabusa on Jan 30, 2013 9:29:06 GMT
Hey Mark,
Aye RTR asked me to get on here, lots of people asking about the first kits apparently. I was going to wait till I had more progress. It's quite informative on here though, I've been scanning through peoples build pages, get some great ideas and hints and tips.
Thanks to everyone wishing us well with the build, best go make some progress
Dean
Post by marshabusa on Jan 30, 2013 17:52:16 GMT
Little bit of progress this afternoon, decided to start stripping the Hayabusa down to get the radiator out. Such a shame to be stripping such I nice example apart, was almost tempted to keep it and try and get another. ready to drop the radiator off stripped a bit further, Any electrical connectors we've disconnected, we've been labelling to make life easier later down the road. Anybody interested in buying some busa bits? ha
Post by marshabusa on Jan 31, 2013 19:12:27 GMT
Only a little bit of progress today, front hubs, discs and callipers mounted. Actually this has created a couple questions. On these alloy hubs, when you dog up the axle nut, how much preload do you put on the bearings? Also how are others locking these nuts, there not nylon lock and the split pin hole is miles off?
Post by airforceone on Jan 31, 2013 19:48:12 GMT
As for the tension of the nut, I was told by my expert mechanic that I needed to tighten the nut up to the washer infront of the bearing then turn it back half a turn as the bearing will expand under heat generated but the rotational friction of the wheel.
I think most have used castle nuts, can't remember the size but if you look through Ade's rocket build and the tech section I'm sure the size is there.
Ned
i
