Post by huggy on Jan 24, 2016 23:29:28 GMT
I have the same dash, and I've had a clumsy attempt to make a centre console to accommodate it, what have you got stopping it from falling out towards the driver? Literally just made a small bracket, braced between both sides of the console. Will take a pic in the next day or so and post. It's not particularly elegant however feels solid enough.
Post by huggy on Jan 25, 2016 23:59:51 GMT
I have the same dash, and I've had a clumsy attempt to make a centre console to accommodate it, what have you got stopping it from falling out towards the driver? Literally just made a small bracket, braced between both sides of the console. Will take a pic in the next day or so and post. It's not particularly elegant however feels solid enough. Here is the pic. Will all be hidden at some point.
Post by casesensitive on Jan 26, 2016 13:21:04 GMT
Here is the pic. Will all be hidden at some point. Yes, that's the ticket, brilliant.
Post by huggy on May 18, 2016 22:54:01 GMT
Finishing engine cover: Tab for lock Cam lock fitted Air intake mesh fited: Number plate lights
Post by huggy on May 18, 2016 23:27:13 GMT
Onto the seats: Seats first fit Basic template for belt cutouts Masked and ready to cut Cuts complete
Post by huggy on Jun 10, 2016 21:52:45 GMT
Edge trim added to seats 8.8 eye bolts fitted for harness Seats fitted
Post by Froggy on Jun 13, 2016 12:17:39 GMT
Have you tried sitting in the seats with the harnesses in place at all? The holes look a little high looking at how my position is in the seat and i have the same seats as yourself-im 6ft btw-so if your taller that may explain it. Sorry to come across like im picking fault but thought it better to mention. Wayne.
Post by airforceone on Jun 13, 2016 13:08:53 GMT
You beat me to it Froggy.
They do seem a tad high unless Mr Huggy Is a tall lad.
Post by huggy on Jun 14, 2016 22:17:59 GMT
Have you tried sitting in the seats with the harnesses in place at all? The holes look a little high looking at how my position is in the seat and i have the same seats as yourself-im 6ft btw-so if your taller that may explain it. Sorry to come across like im picking fault but thought it better to mention. Wayne. Tried today. Felt okay. Will double check tomorrow and tweak if needed. Only 5'10" so maybe they are indeed high. Thanks for pointing out.
Post by huggy on Jun 14, 2016 22:25:26 GMT
You beat me to it Froggy. They do seem a tad high unless Mr Huggy Is a tall lad. A towering 5'10" :-) Will check and tweak next time in garage.
Post by carlostheoptimistic on Jun 15, 2016 7:44:45 GMT
The holes need to satisfy the IVA requirements, that's the important bit. I can't remember the exact details but I think there is a min height above the reference point (your backside on the seat) that the upper anchor point has to be and then the holes in the seat need to be positioned so that they don't made the belt/harness change direction or the seat become part of the structure for the belt anchorage. Something along those lines, I remember the IVA man checking mine with a measuring device. I'd check the IVA manual for seat belts, seat belt anchorage and seat strength.
Post by casesensitive on Jun 15, 2016 9:49:58 GMT
Post by airforceone on Jun 15, 2016 13:29:12 GMT
Yeah, that makes complete sense...lol...
Post by huggy on Jun 15, 2016 20:33:39 GMT
Yeah, that makes complete sense...lol... Indeed :-) You were right guys. Just a bit too high as the belts were just touching when I sat in seat. Easy fix luckily, just a bit late to finish today. Thanks for pointing out the potential IVA/safety issue.
Post by huggy on Jun 16, 2016 22:20:15 GMT
Harnesses fitted. Note: the seat holes were enlarged thanks to the feedback a few posts back. Bigger than my original plan, however still feels strong and very luckily I don't mind the result. I worried I would hate the look of the holes being too big hence feel compelled to upgrade the seats much sooner than planned. Had the harnesses made ready for eye bolts at the bottom and bolt in at the top. Why..., I gave up looking for eye bolts of the correct grade that were also long enough for the job at the top, while at the same time, using clip in fittings at the bottom simply seemed to sit / align much better. Steering wheel fitted: That just leaves the bonnet (using Kiwi's hinge) and the wings. Not looking forward to fitting the wings.
