Post by The Management on Aug 16, 2012 20:34:29 GMT
Checkout the latest developments us5.campaign-archive1.com/home/?u=6c4be0f797a67bd4f36ef0997&id=449292c395Note:- "ClubZone Moves: Having been assured that the infield area would be serviceable for the show it's now clear that, after all this summer's bad weather, the area is in a state. After a couple of recent site visits, we have decided to relocate the club area to outside the main hall. This is not the area used in 2007, but instead an open area near the wood. It's a great spot and there's still access to the infield to watch the racing all weekend. The location is also far closer to the camping area." the Management
Post by Deleted on Aug 27, 2012 15:01:09 GMT
Just letting you know I will probably not be there this weekend. I need to fix an issue on my Brake Light switch, well replace with a threaded bezel really as my brakes have bedded in now so the pedal is nowhere near the button. I have also found the issue on the headlight dim problem so want to make a new headlight loom and fit that too. All things that need doing but which need the nose removing to do, so think I will also fit my Quick Rack at the same time. Get it all done now than do it again in the winter.
Hope the weather holds up for you all.
If I get done I may pop over Saturday evening or maybe even Sunday.
If not, see you at the next events,
Nick
Post by mabbs on Aug 27, 2012 17:24:03 GMT
Just letting you know I will probably not be there this weekend. I need to fix an issue on my Brake Light switch, well replace with a threaded bezel really as my brakes have bedded in now so the pedal is nowhere near the button. I have also found the issue on the headlight dim problem so want to make a new headlight loom and fit that too. All things that need doing but which need the nose removing to do, so think I will also fit my Quick Rack at the same time. Get it all done now than do it again in the winter. Hope the weather holds up for you all. If I get done I may pop over Saturday evening or maybe even Sunday. If not, see you at the next events, Cheers Nick I know I am hardly one to push - as a spot of rain stops play for my Rocket But the green monster must be seen at the show ;D Last major event of the year ? - I hope this will be the best kit car show of the year. If not, hope all the mods go well and obviously safety come first ATB Jon
Post by slugshot on Aug 27, 2012 17:50:23 GMT
Are you going in yours Jon, it will be raining you know. I spent all Sunday stripping and cleaning my tR1ke. I can't imagine how long yours would take ;D
Post by mabbs on Aug 27, 2012 18:10:27 GMT
Are you going in yours Jon, it will be raining you know. I spent all Sunday stripping and cleaning my tR1ke. I can't imagine how long yours would take ;D Hi Kev, I will be gutted if it rains this weekend as this will be the first kit car show the car has been to in completed form. If it does look like raining, I will see if I can get it trailered. I spent the following weekend cleaning my Rocket after Curborough - and it didn't rain all that weekend ;D If it got wet I think I would have to do a re-build thread ;D - I am just not harcore enough Are you coming to Donington ? The trike's look superb and totally unique, hope you can make it. ATB Jon
Post by slugshot on Aug 27, 2012 18:38:08 GMT
ha ha a re build thread very good Yes i will be going with a tent and a full roll of sticky polythene to blank the sides so i don't get a face full when cornering. cheers Kev
mightylad
.....Mighty MEV Rocket.....
Post by mightylad on Aug 27, 2012 19:45:25 GMT
Looks like im booked in for this one.. It'll be Sunday for me...
C'mon indian summer!!!
Ol
Post by Scott on Aug 27, 2012 20:07:45 GMT
Come on folks lets all go,,, Eco-Exo are indoors please come and see us,,, Nick, unless you tripping down to Exeter then this is about the last!! And the summer is nealy over,, that all sounds like a winter job to me!! Come on you know you want too,,, Mabbs! It's got to get wet one day !!
Post by Deleted on Aug 27, 2012 20:35:09 GMT
I don't plan to go to Exeter, Will see if I can get the brake light switch done this week. Yes the rack and lights can be done again for sure Scott, it's just quite important some dumb ass doesn't hit me from behind with the brake lights. and a busy work week this week, due to my fellow work mates not pulling there weight. Might be there to camp in my car maybe, want to come in the TR1KE, but need to find the solution to the brake light, I know what it is, I just need a springy metal plate to munt on the side of my brake pedal, will consult my dads scrap bin tomorrow and see what I can do. If I take the nose off I can fix it quick enough, but its not a 2 min job removing and re-fitting it.
Post by Deleted on Aug 27, 2012 21:04:39 GMT
May have an idea for fixing my brake lights, so will keep you posted on my progress if it fixes it. Calling in at Maplin on the way to work to pick up a momentary switch to mount behind the pedal closer to it.
Post by slugshot on Aug 27, 2012 21:45:38 GMT
Hi nick, if having no brake light is all that's stopping you coming i don't mind being your rear guard there and back.
Post by Deleted on Aug 27, 2012 22:34:53 GMT
hahaha, cheers. I think I will be good to go, found a spare Savage switch not used on my last build, have removed its outer holder allowing the button to press freely, have a bracket, will fit it into the bracket tomorrow, then hopefully do the job Wednesday night and have the brakes up and running Wednesday. Might not be able to get down Friday night due to bloody work I suspect, however if I get away no later than 7pm my end, should be able to get down and setup around 9pm with hopefully enough light, otherwise Saturday morning...
Will keep you posted though. :-)
Post by Paul (madeye) on Aug 28, 2012 7:57:29 GMT
im hopefully releasing the chassis for coating on friday, so may pop down for one of the days. will give me chance to steal some more ideas..
Post by Stewart on Aug 28, 2012 9:11:32 GMT
Well I've just sent over my race entrance for the 750MC event so I'll be out on track Saturday and Sunday
Post by Deleted on Aug 28, 2012 9:20:09 GMT
No. I won't be at Donny as I work with a bunch of lazy tossers. Gonna be here till midnight till Friday.
Have a good one.
Sent from my LT26i using proboards
