Post by roadtrackrace on May 9, 2012 19:22:42 GMT
Hi, We like this picture and hope you do too.................. Some more kit info below to answer some questions raised at the launch. We are now adding this info and the options list to our website at www.roadtrackrace.comThe dimensions are as follows; Length 3300mm Width 1680mm Wheelbase 2260mm The price of the kit in the UK is £4995 + VAT The kit comprises: Fully welded tubular space frame chassis ready to accept 1998 to 2007 Suzuki Hayabusa components. Protech fully adjustable shock absorbers complete with coil over springs. Front and rear wishbones complete with poly bushes, crush tubes & ball joints. Rear uprights complete with hubs, bearings and brakes. Alloy front uprights and hubs with radial brake caliper mount to accept Wilwood/Hi Spec/A.P. etc radial caliper Rear alloy bulkhead, alloy centre console and alloy sheet for floor. 5 piece GRP set in the colour of your choice comprising: bonnet and 4 wings with mounting brackets (choice of styles) Front grille Alloy radiator pipes (for front mounted radiator). Twin fuel tanks Steering column (used) Steering rack complete with trackrod ends. Brake, clutch and accelerator pedals Brake master cylinders and balance bar The wheel fitment is Ford 4 stud (4x108) Overall weight of the vehicle is in the region of 400kgs. Now taking orders Regards Road Track Race
Post by roadtrackrace on May 9, 2012 20:52:38 GMT
olberj
SC Rocketeer
Post by olberj on May 9, 2012 22:43:29 GMT
The proportions of this are so spot on. It's the one thing about the rocket that just wasn't quite right.
You've nailed this one though. Very impressive.
olberj
SC Rocketeer
Post by olberj on May 9, 2012 22:48:38 GMT
Btw, what size wheels are they?
