Post by Deleted on Dec 21, 2014 23:40:23 GMT
Too much power, :-)
Post by andy7b on Dec 22, 2014 17:40:27 GMT
Looks mental and brilliant all together:-)
Post by juddyjuddster on Dec 23, 2014 7:21:39 GMT
Well done I think you need some hot grippy Tarmac to test that beast to the full, roll on summer.
Post by slugshot on Dec 23, 2014 11:11:00 GMT
Don't be daft nick, there's no such thing as too much power I was happy enough with the r1 motor until bob'n came up with the mev trip up north. And as you sold your tR1ke I knew you'd want to come...so with you and your caravan in tow and all those hills in Scotland, I thought It was a good idea.
Post by Deleted on Dec 23, 2014 11:29:33 GMT
Yeah I see your point now, with my fat arse providing much stability and traction, this will need to be a much more powerful device in order to tow the caravan too, and all our camping gear for sp00ning?
Post by martinw on Dec 23, 2014 11:38:03 GMT
.....sp00ning has been mentioned all too often! Anyone would think you'd got a fixation Nick Can't wait to see the tR1aturbusa in the flesh too Kev (.....arghhh......sorry....mentioned flesh; it'll probably set Nick off again!) Martin
Post by andy7b on Dec 23, 2014 19:18:02 GMT
Have you had have to weigh it yet?
Post by slugshot on Dec 23, 2014 20:51:43 GMT
Have you had have to weigh it yet? You been on the plonk already andy, lol I haven't got any way to measure it accurately enough,it would max out my old method with the bathroom scales. I would say at least 40-50 kg more than before, the motors 20kg more plus the dry sump tank and the extra 3L oil it holds,plus the swirl pot and high pressure fuel pump, plus.....
Post by slugshot on Jan 3, 2015 22:01:43 GMT
Well, after failing miserably at trying to put weight on over christmas to gain a bit of ballast (traction) I swapped the worn out toyo r888 for a normal road tyre. It grips much better in this cold weather, but still can't give it more than half throttle should be ok in the summer though I still might need a lardy passenger. PS... turn sound to max
Post by Deleted on Jan 3, 2015 22:06:56 GMT
Cheeky forker.......
Post by andy7b on Jan 3, 2015 22:48:16 GMT
Maybe tow a caravan too :-)
Post by Deleted on Jan 3, 2015 23:16:30 GMT
there's a 450bhp busa turbo lump for sale if you fancy taking it a notch further quarter throttle max maybe?
Love it mate.......
Post by slugshot on Jan 4, 2015 0:31:45 GMT
Err better not matty but I know of a mevabusa that it would suit really well
Post by james13009 on Jan 4, 2015 17:25:49 GMT
Nice!
Post by slugshot on Jan 18, 2015 22:36:03 GMT
A couple of updates done this week, the first is a re positioned fuel filler. This is an 80L per min water pump which is controlled along with the fan by the little flashing box of tricks under the busa clocks, the pump and fan will automatically keep running after the motor is switched off if the temp is higher than a pre set temp. This pic shows the new gear poss indicator, it also fools the ecu into thinking the motor is in a high gear, this eliminates the power restrictions that nasty Mr suzuki fitted Also you can see the combined oil pressure and temp gauge, yes the temp tonight was 3.4...nice.
