Post by slugshot on Feb 14, 2012 22:02:17 GMT
Hi chaps, to answer your question regarding the handbrake cable,i've made a alloy block thats bolted with a countersunk 10mm bolt through the back of the caliper bracket, i've made it long enough so i can get a ring spanner on the wheel spindle nut. Ill put a pic of it on here tomorrow.
eric, i think venom sorted his handbrake by takeing the slack out of the cable and got it working well,i hope. vtR1k thanks for info on the caliper thread size, i just need brake master cylinder thread size, i think they are wilwood looking at the pics.... cheers.
Post by Deleted on Feb 15, 2012 0:07:40 GMT
vtR1k
I'm a trike lover...
Post by vtR1k on Feb 15, 2012 20:32:32 GMT
Hi chaps, to answer your question regarding the handbrake cable,i've made a alloy block thats bolted with a countersunk 10mm bolt through the back of the caliper bracket, i've made it long enough so i can get a ring spanner on the wheel spindle nut. Ill put a pic of it on here tomorrow. eric, i think venom sorted his handbrake by takeing the slack out of the cable and got it working well,i hope. vtR1k thanks for info on the caliper thread size, i just need brake master cylinder thread size, i think they are wilwood looking at the pics.... cheers. Master cylinder is UNF 7/16-20 or 9/16-18. Definately they are willwood, so you must be able to find it on their website. Sent from my HTC EVO 3D X515m using ProBoards
Post by slugshot on Feb 15, 2012 21:19:01 GMT
Thank for m/cylinder info,i was'nt sure if it was willwood. Here is a picture of my outer cable holder, I hope its strong enough, i would of preferred to of welded it but i hav'nt got a tig welder.
Post by Deleted on Feb 15, 2012 23:07:26 GMT
Nice neat job, it looks strong enough, you could always ask Luke at RTR to weld it for you. I would weld it, had my bloody TIG not packed up....
Post by slugshot on Feb 16, 2012 0:05:09 GMT
Nice neat job, it looks strong enough, you could always ask Luke at RTR to weld it for you. I would weld it, had my bloody TIG not packed up.... yeah good idea venom, i suppose its better to be oTT than it snap off.
Post by Deleted on Feb 16, 2012 0:07:42 GMT
I don't see it snapping off, it looks pretty substantial
Post by erik on Feb 16, 2012 11:02:30 GMT
[quote author=slugshot board=tr1ke thread=2151 post=15327 time=1329340741Thank for m/cylinder info,i was'nt sure if it was willwood. Here is a picture of my outer cable holder, I hope its strong enough, i would of preferred to of welded it but i hav'nt got a tig welder.[/quote] That looks like the duck's nuts!! I would like to have a shameless copy of your bracket LOL!!
Post by slugshot on Feb 16, 2012 18:28:35 GMT
Cheers eric, be as shameless as you like, im sure you will come up with ideas to help me when we start our builds.... do ducks have nuts
Post by Deleted on Feb 16, 2012 21:00:15 GMT
So do you think you might be built for Newark Kit Car Show?, if so, do you fancy joining our convoy down?
Nick
Post by slugshot on Feb 16, 2012 21:34:35 GMT
Hi nick. i'll be in my garage every night +weekend to try and be done for a convoy to newark, im in Hull so i don't know how that would work.
You know better than me how long it takes to do even the smallest of jobs. Im going through all builds on the forum trying to work out what i need, even daft things like bolt lengths on suspension, anything to give me a head start, cheers
Post by Deleted on Feb 17, 2012 7:13:09 GMT
Hi Slugger,
Once I know I have passed MSVA, I will give you a run down of anything you need, no point until then as I could be mis informing you, then at least I can measure things, give accurate dimensions and heights of things. As soon as my TR1KE is home I will get whatever info you require to speed up your build.
Post by erik on Feb 17, 2012 8:09:40 GMT
I am trying to work ahead in research as much as possible so I have more building fun in a nice pace. Still I noticed many things are not posted in clear writing for reference purpose which consumes a lot of time to sort out. I think I am close to an 80% wishlist at this moment regarding accessoiries which seems to be the most difficult part LOL!!
Hehe, I hope some do a shameless copy on my build. If not it wouldn't be of any use to contribute to a forum right?
Erik
Post by Deleted on Feb 17, 2012 11:36:52 GMT
Ask away, I will answer as much stuff as I can?
Post by slugshot on Feb 17, 2012 21:58:09 GMT
Hi Slugger, Once I know I have passed MSVA, I will give you a run down of anything you need, no point until then as I could be mis informing you, then at least I can measure things, give accurate dimensions and heights of things. As soon as my TR1KE is home I will get whatever info you require to speed up your build. Thanks that will help a lot....... I ordered brake hoses + fittings today, I'm going to have a go at making them up myself. Next on my list of things to decide on is what wheels to get,yours look nice and light as well, ill go for white though and i can't decide weather to go with 15 or 17in. I don't suppose you know what the dimensions the hub fittings are, the teem dynamics website quotes 108, i assume that's the stud centres and 35mm offset, i thought the kit setup needed 38-40mm offset.
