Post by leahy on Jan 27, 2012 13:27:49 GMT
Hi
lightweight looks really good, im torn between the exocet and lightweight now, looking forward to seeing the chasis and finished product
good work,
trident
Improvise, Adapt and Overcome
Post by trident on Jan 31, 2012 21:14:48 GMT
Ok .. with an MX5 outside being stripped in readyness for a new life .... do I need to keep the remaining door for this lite version of the x5 or are the doors on this kit fiberglass.... What else should I keep from the body of the donor MX5 should I have a change of heart from the Exocet to this? Oh and some more photos when you've got a spare second PLEASE.... Cheers Trident
Post by Stiggy on Jan 31, 2012 22:23:14 GMT
Sorry if I have presented to many options, I can't help myself! We keep the MX5 doors. All other body parts are sold on. We cut the guts out off the doors to lighten them but retain the side impact bar. We supply door caps in the grp set. The green part of the door in the picture is the metal MX5 door. The caps just stick on with PU adhesive.
Post by tttawesome on Feb 8, 2012 20:09:18 GMT
I really like the look of this, could you make a roll cage or continue the spaceframe from the superlight into the roof for a coupe body? Also does the superlight need to pass the IVA because of the new chassis.
Post by Stiggy on Feb 9, 2012 9:37:27 GMT
It would need an IVA test due to the new chassis, it is aimed at the race market so unless someone wishes to join Britcar then I am sorry but I do not plan to make a Coupe version. I could spend months making moulds to form air/water tight doors, inner arches, bulkhead seals, window seals etc and then only sell a couple! An MSA spec full cage can be ordered with this kit at £800 extra. It would spoil the look though. I would prefer to supply an MSA spec roll bar. Mine will have a bar to match the rear cover shape.
acra
Newbie
Post by acra on Feb 19, 2012 19:41:25 GMT
I'd be interested in seeing more of this new back end - the one with the 6 light clusters. Always thought the double-cluster varient seemed a little lacking, so would be great to see!
Post by kerrymann on Mar 3, 2012 21:54:48 GMT
I am in the midst of building a electric MX5 right now (my second EV) and I am really interested in how the superlight turns out. I planned to turned mine into a sppedster once I get it rolling on the road. I look forward to seeing pics of the chassis and getting a final weight. Please keep us posted.
Post by theoxke on Apr 2, 2012 9:11:05 GMT
Have you got a side by side picture of the front & rear options? Julie took the only picture and there is a bloke standing in the way! Not long though for a proper photo shoot. There were some drawings of both on here, can't remember where.
Post by christof on Apr 8, 2012 21:29:52 GMT
The 'lightweight' spaceframe chassis version looks great! IMO your best creation yet
My thoughts- old mx5s rot from inside out on sills and rails so great to see space frame chassis. 'lightweight' name confused me with Exocet lightweight Hope this new version doesn't get confused with body-kit original mevx5 Interested to see different front look Heard doors are hard to get right?
Pls tell me this will be at stonleigh
Previous post edited due to inability to read thoroughly!
Post by christof on May 15, 2012 19:16:46 GMT
Stuart I have just noticed a discrepancy between the superlight price on the attached pdf and the blue leaflet from stoneleigh - please can you confirm (hopefully the lower one!)
Post by Stiggy on May 17, 2012 16:27:45 GMT
Stuart I have just noticed a discrepancy between the superlight price on the attached pdf and the blue leaflet from stoneleigh - please can you confirm (hopefully the lower one!) Hi the Superlight complete kit inc lights, headlight covers, nut bolts adhesive, tunnel, dash, instrument pod etc etc, is.... £2895 plus VAT This price includes the clam shell front with steel work for a hinge and door pillar plates for door hinges.
Post by christof on May 17, 2012 19:35:21 GMT
Thanks Stuart. The bluey/purple leaflet from stoneleigh can go in the bin then!
Post by langy26 on Aug 23, 2012 22:01:19 GMT
