Post by Stewart on Aug 16, 2012 12:30:28 GMT
Have you tried JK Composites?
Post by pincherrn on Aug 16, 2012 12:37:21 GMT
Hi Freak,
I hadn't but just checked them out. May be the type of thing. I was thinking more of just the foam pads but the price of the JK things isn't too bad. We have Intatrim around the corner from me too, may go and pay them a visit.
Colin
Post by stevieboy on Aug 16, 2012 19:22:41 GMT
Hi Guys, Red, been doing abit since i came back from hols, will have pics over the weekend, got the induction kit on, wheel spacers fitted, carpets cut, waiting for glue to arrive. All the lights are wired and working, but not yet fitted, want to get the suspension ride height correct before fitting so the iva man will be happy . Pics to follow. Colin, hi, The small pads you mention, can be ordered in any size you want, go on their web site and see the sizes they do, measure your seats up and give them a call. they do other colours than those advertised.
Post by h5ngs on Aug 16, 2012 21:49:05 GMT
Go on ebay and search "self adhesive closed cell foam" you can buy it in loads of different thicknesses and sizes. It peel back and stick on and very easy to shape at a very good price too
Post by pincherrn on Aug 17, 2012 8:29:54 GMT
Ahh. That is the tip I needed. What it was called. Race seat foam etc brings up the small bits and the proper 2 part racing seat expanding foam.
Will look later.
Colin
Post by stevieboy on Aug 19, 2012 18:38:35 GMT
Had a good weekend on the car, got the induction kit fitted, so that leaves just the headlight wires to plumb in then the bonnet can go on for good. Bonded the grill mesh on and then bolted the front into position. Cut the side panels and fettled them for fitting later. Due to having 215s on each corner i needed to fit the lights off the rollbar / suspension turret. I made an L shape bar and fitted lights to the top and bottom of it, they are 350mm from the outer edge so iva friendly . The fog light is straight onto the chassis and the reverse light will go on the other side. Getting near the end now and thinking when to book the IVA crumbs did i actually say IVA ;D
Post by welshy1 on Aug 19, 2012 19:29:34 GMT
Not seen that set up for the back lights before looks good. Just one thing even though you have a heat sheild over the exhaust there will be a lot of heat coming from the manifold which isn't so good for the air filter idealy it needs a cold air feed to stop heat soak when the engine gets hot.
Post by stevieboy on Aug 19, 2012 19:44:14 GMT
I had thought about that, but with no sides on the car i think there is enough draft to feed the filter and disperse the heat at the same time, hopefully will find out soon.
Post by squelch on Aug 19, 2012 20:12:59 GMT
my airfilter is similar to yours (although a little further back) and ive had no issues as of yet with heat soak, as you've said its got good ai flow in that area
you might have and issue with the fog light on the IVA as it needs to be 100mm from the brake light IIRC
Post by gwnwar on Aug 19, 2012 20:25:19 GMT
They make square plastic plugs that will fit in the ends of that alum stock..it would finish off the bracket after painting it.. don't know your IVA regs but can you just change the lamps top to bottom or does the red have to be on the bottom..
Post by stevieboy on Aug 19, 2012 20:32:32 GMT
Cheers for the filter info, The fog light although it doesn't look it is 110mm away, to be absolutely certain i can swap it with the winker and put it at the top.
Post by mathew on Aug 19, 2012 20:51:33 GMT
Absolutely love that colour Where are the seats from? im sure i found them on ebay a few weeks back but cant remember what search terms they came under
Post by stevieboy on Aug 19, 2012 21:08:27 GMT
Hi Mathew, thanks for the comments, the seats were off ebay this is the sellers name .....marleymoos...... drop him a message, he seems to have plenty, £15 a pair and is based 1 mile from J3 on the M5 at birmingham.
Post by driver on Aug 21, 2012 16:09:12 GMT
Hey i messaged marleymoos, he dont have any of them seats left :-( anyone know where else i can get them from?
Post by PardonWhat on Aug 21, 2012 20:08:37 GMT
Hi stevieboy, great looking rear loght setup. I hate to put a spanner in the works at this late stage but I remember reading in the IVA manual threat the brake lights need to be a minimum of 100mm from the fog light. I had to change my setup as a result. I'd be happy to be proved wrong but might be worth doing some digging.
