Post by gwnwar on Oct 3, 2012 12:50:30 GMT
Noticed the gear shift sits alittle high at least in the pics.. you might want to loosen the bolts on the PPF at the trans and drop the rear of the trans some.. Just an idea..
Post by h5ngs on Oct 5, 2012 18:16:39 GMT
Yeah there is a spec in the workshop manual about the height of the ppf, it was to stop the annoying noise on overrun the buzz that all mx5s with the 6" diff have, ive upgraded to the 7" LSD with rubber mount so shouldnt have a problem, im also stripping the car down for powercoating so will adjust the ppf to the required specs then, ill also be going over every nut and bolt loosing and retorquing to mazda's specs when the final rebuilt happens, its also good to pen mark each bolt once done so you know its been torqued up.
Post by gwnwar on Oct 5, 2012 19:00:11 GMT
Good idea on the torque stripe.. remember having to do that on all lines and fitting on the Lunar Module space program.. boy that's a long time ago..
Post by h5ngs on Oct 5, 2012 21:03:10 GMT
Post by h5ngs on Oct 7, 2012 21:09:42 GMT
Post by h5ngs on Oct 12, 2012 20:15:46 GMT
ITS ALIVE ................................................................
Post by h5ngs on Oct 13, 2012 8:28:34 GMT
Well spent a few hours on the car last night, figured I'd stick some fuel in and fire her up .... well that's what the plan was anyway, I fitted the fuel tank then temp fitted the fuel pipes and hoses just to see if it would start. fully charged battery at work and ................................................................ pop pop bang bang ......pop pop .........nothing .... :S ........ ohhhh s**t!!! I tested the fuel, spark, and air all the vitals for combustion, all okay, So compression test it is then. Straight away I could see it was not holding compression on cylinder 2 so must be valve timing it also had that sounds of firing at the wrong time, so on with the strip down of my lovely cleaned and painted engine it is then ....... Sure enough id timed it 180degrees out on the cams. Note when checking the cam timing, with cylinder 1 at TDC and the crank mark lining up the marks on the cam sprockets should line up, which all my marks did, however check the cam lobes on cylinder 1. The intake cam lobe point should be facing 9 o clock and the exhaust cam lobe point should be facing 3 o clock, i.e both facing outwards, well both mine were facing inwards, so quick pull the belt off re-time and rebuild. Ta daaaaa first turn of the key it fired up now that's sorted i can finish off all the niggly little parts of the build.
Post by tomelliott on Oct 13, 2012 12:07:54 GMT
Congratulations on getting it fired up! Really enjoyed reading through this build thread so far.
Post by welshy1 on Oct 13, 2012 18:39:22 GMT
Great feeling the first time it starts up. Dont worry about the timing done a similar thing on a megane in work which is an easy mistake on them awkward to time up properly.
With the wiring loom i have a similar sized box full with unwanted wires surprising how much there is to remove and how much there still is on the car.
Great progress on the car can't be long till your ready to strip it down for powder coating.
Post by h5ngs on Oct 14, 2012 19:07:47 GMT
Yeah there is a lot of wiring that can be removed in the harness, to be honest if i can be bothered there is still a lot to remove. Most of the wires could be shortened to make the loom even smaller but would mean cutting and soldering around 100 wires, lol maybe later I'm not too far off the strip down however there is still a list of little jobs that need doing, make rear bulk head panels, mount hand brake brackets, fit fuel pipes, fit battery, mount battery wiring ....etc.... then make a start on the body panel fixings. I think the very last job on the car will be mounting the wing stay brackets and wings as i think this will be the worst job of all
Post by welshy1 on Oct 14, 2012 19:37:23 GMT
Same with me really don't fancy shorting the rest of the loom. Even though i mocked up as much as possible there are still things i forget and have to drill in to fresh paint which i hate doing. My last job will be the wingstays and wings will need spacers first to get it in the right position.
Post by malcolmmazda on Oct 14, 2012 21:56:57 GMT
I love the angled shelf idea to store the electrical bits'n'bobs - never thought of that but cleverly obvious when you see it!
How is your instrument binnacle secured? I can't see any fixings! All the completed cars have it mastered in some form but I can't make my mind up how to do it! Thoughts from anyone or everyone appreciated here!
Post by malcolmmazda on Oct 14, 2012 22:01:49 GMT
Ps - very nice neat wiring job (I now have niggling thought in the back of my mind that I should do the same but sadly laziness will undoubtedly take precedent for the time being - and the best weight saving I really need is to trim some off the driver - lol!)
Post by h5ngs on Oct 15, 2012 20:00:18 GMT
I havn't secured the instruments yet as i still don't really know how haha, not made my mind up yet, so far I've made 2 different brackets and didn't like either so will have to have another rethink.
Post by h5ngs on Oct 16, 2012 18:02:23 GMT
Popped in the garage after work tonight just to sort the timing and run the engine, put water in the system and ran it up to temperature to make sure the fan kicked in which was fine, had a small issue with a seal leaking but easily sorted once i drain the system again. Slight issue with the coolant bottle as i found it kept coming out of the over flow pipe, maybe because i mounted it lower than the radiator cap but in theory it shouldn't make a difference due to the design on the system but its something to look at. I adjust the idle once warm and set the ignition timing to 14 degrees to give a bit more power low down, then ran the engine at 3000 rpm to get the hydraulic tappets filled with oil which stopped them tapping I've took a short video which is uploading so will post when its done, this shows my rear light set up too. I've gone for 6 function trailer lights so covers everything in a nice small neat unit, easy to fix as well and e marked so should have no issues come IVA. Am getting there but week off next week so should be getting hopefully the rest of the work done so I'm happy with everything before I start the strip down
