Post by kitcrazy on Jun 7, 2011 21:02:28 GMT
Gone and put everything back in the engine bay and now can't see where the eingine number is located? ? Also are these vehicles classed as being previously registered for the IVA form Cheers for any help KC
Post by Deleted on Jun 8, 2011 9:53:49 GMT
if you have a 1.6l its on the drivers side, on the flat block anobe the starter motor, if its a 1.8l i believe its on the other side. Alex
Post by kitcrazy on Jun 8, 2011 20:26:22 GMT
Thanks for advice though all i can find are the letters BP which is all i can find on my old engine block which is still kicking around, its a 1.8 btw. Another thing is that the notes on the iva form state that youmust prove the age of the engine, ok if its the original engine as the v5 will prove it but if like me you have a different engine in then where does one find documented proof of its age?
What with what you were saying about making the car road legal it seems that getting through the IVA process is harder than building the bloody thing!!! not to mention as about as expensive.
Alex, Did you need to mot yours as another thread is suggesting?
KC
Post by Deleted on Jun 9, 2011 11:32:50 GMT
on the first IVA we couldnt see the engine number, but the chap looked at the original V5, plus original Vin numbers and seemed happy, and suggested i cleaned the number up for future ref (if i could find it) although he did forget to put this point down for the retest, the engine number should be on the V5 and should start with BP-
In ref to an MOT i keep hearing conflicting stories. DVLA seem to have advised me that as its classified as a new car its MOT exempt for 3 years. they havent asked for an MOT certificate for tuesday when theyre taxing the car.
Alex
Post by fasteddie on Jun 9, 2011 19:21:17 GMT
Hi lads. I`ve got 3 donors, 2 1.6s and the 1.8 in my car. I have all 3 VC5 none of which record the engine number and I have yet to see any on the engines. Sorry have to go now my guide dog is barking.
Post by kitcrazy on Jun 10, 2011 9:47:19 GMT
Looks like there ain't any numbers on the engine which will save my bacon as the engine is different from the original Surfering from wiring loom hell at the moment, anyone know what to do about after market immobolisers that are in a sulk?
outlander
" Drive it like you built it ! "
Post by outlander on Jun 10, 2011 10:27:34 GMT
Just a note on the IVA for proof of age for the engine, if you cant prove the age of the engine they will test the emissions to current regs.
That is what I was told by the IVA inspector when my Sonic was in for its IVA.
For the engine number the IVA inspector did not check mine it was only when the car went for its DVLA inspection for registration that the DVLA inspector looked for the engine number.
I hope that this may help
Post by Deleted on Jun 10, 2011 11:45:18 GMT
Mine goes into the dvla on tuesday. So we'll see what happens as mine doesnt have a legible number. As for immobilisers, as long as the steering column lock works, you don't actually need one. With a bit of patience they're fairly simple to take out. Just unwrap the whole ignition section of the loom and there the immobilisers been spliced in, cut it out and reconnect the original wires, which are all coloured different so fairly simple to figure out. Alex
