Post by fasteddie on Jun 2, 2011 20:12:34 GMT
Please be aware as advised by our Lord Sir Stiggy Mills. although my petrol filler cap looks great I can remove the key from the cap when it is unlocked therefore it must be tethered to the vehicle. I have done this by using a piece of throttle cable and a couple of cable crimps inside the filler neck. If you buy a cap that captivates the key whilst unlocked then this is not required, or if the cap is hinged. Hope this helps others so as not to fall foul at the IVA.
