Post by fasteddie on May 31, 2011 17:06:00 GMT
Warning,warning, warning. Change the water pump while you have the chance, ie when changing the cam belt. I didn`t and after completing the build and having racked up about 100 off road miles I decided to put in some anti- freeze and the rest is history. Once round the yard and water every where from the pump shaft seal. New pump £38-00+ vat. time to remove radiator, cambelt covers, cam belt cam gears, pump, re-build re-time and test 3 hours. ( and I`m an engineer with full workshop facilities) The advice is in this months CKC Magazine. Boy what a Prat. regards Exoceteers. Ted
