Post by Deleted on Jul 27, 2011 8:34:52 GMT
Got my bits from Car Builder this morning, lightning fast service, can get the brake master cylinders done this weekend.
Post by edwinwl on Jul 27, 2011 10:51:31 GMT
The black, frame, floor and fuel tanks look very good! Please share the pictures.
Post by Deleted on Jul 27, 2011 12:13:27 GMT
Cheers, I will keep posting pics, just got my centre tunnel made in thinner material, and its taller too, it now sits at a nice height with regard to my seats, think I will place my Handbrake down in the tunnel, running cooling pipes underneath, and also put a manual shifter in the centre console as its main or backup shifter. will get centre tunnel done in black when I have cut the relevant access holes. Loving the build so far, hope do do loads more this weekend. Aim to get my kit built for maybe October or November. :-)
Post by Deleted on Jul 28, 2011 13:36:12 GMT
Brake pot bracket mounted and brake pots secure, all 7/16 bits fitted, just going to run the pipework and thats the first part of the brakes sorted, next step is to decide which way I will have my brake supply pipes, not sure whether to do pre-made goodridge type or whether to make my own from Kunifer.
Post by Deleted on Jul 29, 2011 18:00:44 GMT
Chassis now turned round ready for more work tomorrow, plan to fit the seats, or at least make them fit, loosely fit the radiator (brackets being made by my buddy), plumb the brakes in, have checked the centre tunnel clearance for pipes, I have stacks of room now, will also mark and cut for my handbrake access hole in the centre of the tunnel, may jigsaw out the rear floor in engine bay, to assist as much clearance as possible, rear wheel to collect from tyre balancing tomorrow, and may fit the swingarm too, who knows may get the engine fitted if i get a good day :-) Pics to follow tomorrow
Post by Deleted on Jul 30, 2011 18:02:24 GMT
A bit more progress, its funny, the things that take ages to do, I thought open frame, the seats will be easy, maybe I didn't measure correctly, anyway they are loosely fitted now, I need some spacers to step them up over the seat belt mounts, not problem, got the swingarm in, will need a bush to take up the extra space on the swing arm shaft now there is no frame. had some spare braided hose, enough to make the rear pipe anyway, have fitted that on the left brake master cylinder, have centre tunnel cut for mounting the hand brake, have cut the dial cut outs for my trim panel for the dash, will powdercoat this and the grill next session, will mount the radiator and get the coolant pipes in place when my brackets are ready, hopefully Monday. Here are some pics of my progress.
Post by Deleted on Jul 30, 2011 22:06:12 GMT
just ordered a shed load of silicone hoses :-)
Post by latemarch on Jul 31, 2011 11:19:10 GMT
Why is your rear caliper on upside down?
Post by Deleted on Jul 31, 2011 20:03:24 GMT
It's not, its correct. Depending on age of bike will determine if its mounted top or bottom side. This is the correct mounting for my age of bike.
vtR1k
I'm a trike lover...
Post by vtR1k on Jul 31, 2011 21:24:48 GMT
Looking good! Not wasting any time, are you ?
Post by Deleted on Jul 31, 2011 21:37:00 GMT
No, Im loving it too, got several custom brackets being made, so won't be much progress this week, getting front tires on Sat, so can put Trike in its wheels, then look at fitting the engine and getting it all plumbed in. Should be able to get the radiator fitted this week and plumbed to the engine bay.
Post by fuoriserie on Aug 1, 2011 13:12:53 GMT
Nice build and like the colour choice...
Post by Deleted on Aug 1, 2011 19:56:37 GMT
Silicone hoses now fitted at the front, radiator loosely fitted, need some nice top mounts but its secured at the bottom. Front indicators fitted onto MSVA brackets. May move after the test. Pics to follow. Just picked up some nicer than jubilee clip clips to secure the hoses, also just received the water temp housing to plumb into the front area of coolant pipe.
Post by Deleted on Aug 3, 2011 8:50:44 GMT
25mm clips were far too tight once the pipe is in, just swapped for 32-35mm instead, and picked up 25 x 25mm P clips to secure coolant pipes in the tunnel on custom made brackets.
Post by Deleted on Aug 3, 2011 11:26:11 GMT
Just pricing up cables :-( its going to be an expensive do this, I need 5 major cables, throttle, clutch, hand brake, gear shift cable and choke. Certainly the throttle and clutch will need to be custom, so maybe £100 here. Think I may just use a cheaper hand brake and choke cable for now, as all these cables could cost me a startling £250 :-(
