Post by airforceone on Sept 11, 2011 20:02:03 GMT
Hi Andy
Nice seats, I've been looking at those and the ones from Intatrim. What seat runners have you bought, I was going to get the CBS runners as they do them in 2 sizes.
I will have a look around the Stafford show on Sat, I think CBS will be there.
Ned
Post by andybaird on Sept 11, 2011 21:27:26 GMT
Hi Ned
I had a set of runners from the blue seats that didn't fit. They are a wee bit short for the new seats mounting points but I extended them with some flat bar. Hope this helps
Cheers Andy
Post by andybaird on Sept 13, 2011 11:07:11 GMT
Hi All Look at what was delivered today. 50mm Wheel Spacers from e-bay. Very happy with the quality. Cheers Andy
Post by avantkiwi on Sept 15, 2011 16:07:16 GMT
Same as mine :-)
Post by andybaird on Sept 22, 2011 16:15:28 GMT
Hi All Had a few day's off but the weather has not been great. Still got a wee bit done with the fuel filler. Cheers Andy The problem now is the fuel pump doesn't prime now when I turn the ignition on. I must have done something when I have been tiding up the wires in the engine bay.
Post by andybaird on Oct 8, 2011 13:10:14 GMT
Hi All Just a wee update on the progress. Weather has not been good so progress has been slow. I have drained the water out & refilled with ant-freeze ready for the winter. Also started to make the fuel tank cover & fit the mesh on the front grill. The new mirrors also arrived today. Photo's below. Working away next week then off to the USA for two week's the following week so this will be the last update for some time. Cheers Andy
Post by andybaird on Nov 9, 2011 14:18:47 GMT
Hi All Been away on holiday so not done any work on the kit. I'v been all the way to Florida and all I got was two fab T Shirts . Hope to do some work on Kit over the winter but it will depend on the weather. Cheers Andy
Post by jonb2010 on Dec 10, 2011 22:35:07 GMT
Where the cooling hoses runs past the exhaust, we have made them in Alu pipe and that is now fixed to the bulkhead. Flexible hoses each end will allow for engine movement. (we hope) From memory, in the rear we are using: 4 x 32mm 90 degree bends 1 x 32mm 135 degree bend 1M x 32mm flexible hose 1 x T piece (2 x 32mm + 1 x 19mm ) 1 x T piece (3 x 19mm ) 1 x 1M 19mm flexible hose 2 x 1M 19mm Alu pipe 1 x 0.5M 9mm flexible hose Do you know what pipes are needed for the front ? Trying to get mine ordered this weekend
Post by jonb2010 on Dec 10, 2011 22:43:07 GMT
Hi Andy have you got a pic of how you fixed the bracket up for the steering column ?
cheers Jon
Post by andybaird on Dec 10, 2011 23:27:44 GMT
Hi Jon
I used 32mm 90 degree bends on the front. 3 X 90 degree bends + 2 X 32mm connectors on the drivers side and 2 X 32mm 90 degree bends + 1 X 32mm connector on the passenger side.
As for the bracket for the steering column I used a bit off angle iron with a large hole in it for the rose joint and two holes for bolts to fix it to the plate on the frame,
Hop this helps you. Let me know if I can help you any further
Andy
Post by jonb2010 on Dec 11, 2011 0:02:26 GMT
Post by andybaird on Dec 11, 2011 0:17:54 GMT
Hi Jon
Yes that's the ones I used
Andy
Post by jonb2010 on Dec 11, 2011 0:22:45 GMT
Did you get your pipes from DPH ? Can't find any 135 degree bends on their site.
Post by andybaird on Dec 11, 2011 0:37:37 GMT
Hi Jon
I cant remember the name off the manufacture of the hose that I used. I got them from the local auto shop (Wheel Nut's) that has been very helpful during my build. I will look tomorrow as the name is printed on the hose.
Andy
Post by andybaird on Dec 11, 2011 0:47:43 GMT
Hi Jon
Looking at the photo on page 2 it is AHS the is the manufacture. I used some 135 degree at the back so they do do them.
Andy
