Post by edwinwl on May 15, 2011 11:23:57 GMT
Past weeks my work, holiday, social life and some unexpected home improvements, kept me busy. Anyhow in the time between I managed to sell parts from my donor bike and picking up missing parts. Finally found and ordered a coupling that should match the Sierra steering rack. After receiving this I have to find a way to get the mechanism working between the pedals. It will be a very tight fit. At a breakers yard I found my Focus Mk1 gear shifter with cables. However it was still mounted in the wrecked car. Agreed I can pick it up later this week. Also ordered parts for the plumbing. Originally the radiator is the highest point in the cooling system. For the new situation it is not. Thinking: - how fill the system? Lifting the front end of the car before filing or making a new filling point? - where to place the expansion tank? By the way: I painted the pedals.....
vtR1k
I'm a trike lover...
Post by vtR1k on May 18, 2011 17:09:26 GMT
I think normally the expansion tank is the highest point, otherwise air would be trapped inside the system, resulting the cooling system to fail... But I'm not really sure... To fill it: first find out how much coolant you need (must be written somewhere in the specs). You will need more then that because of the extra piping and hoses, the amount can be calculated... Then just fill the system until it looks full. Squeeze some hoses to make the air come out. Start the engine so the waterpump will create a flow. Always make sure the expansion tank keeps full! At a certain point, the themostatic valve will open and the radiator will be filled. Air will come out so keep the the coolant at the correct level. Keep squeezing some hoses in the mean time until the coolant level keeps steady and you see coolant come out of the little expansion hose. If you don't trust it, you can also try to open a hose clamp somewhere high in the system to vent air and to check if there also is coolant. Careful, HOT!
Post by edwinwl on Jun 5, 2011 16:04:50 GMT
Last weekend had some time to work on my tR1ke. Being an electronic engineer, doing mechanics is different and takes more time. (But I am proud of my result...) The modified gearshifter: I have blocked the left-right movement by some bindings and cut the according lever: The difficult part of the shifter:
Post by edwinwl on Jun 5, 2011 16:09:02 GMT
Movies of my effort:
And this one:
Post by edwinwl on Jun 18, 2011 17:15:11 GMT
Picked up the front wheels: Made a support for the radiator: From the Dutch Marktplaats (eBAY-like) purchased rails (Left original, right modified.):
Post by edwinwl on Jun 18, 2011 23:24:50 GMT
Rails ready, front view: Rails ready, side view:
Post by anglais on Jun 19, 2011 17:03:39 GMT
Good stuff, like the wheels
Post by edwinwl on Jun 26, 2011 11:10:02 GMT
My car is on wheels and the wheels are on small trolleys to maneuver the car around the garage: Further more I am working on the steering rack. Have to find out how the quick rack will fit....
Post by anglais on Jun 26, 2011 13:51:50 GMT
If you go onto the technical section there is a really good thread for changing to a quick rack, thats how i sorted it! looking good .
Post by edwinwl on Jun 27, 2011 11:12:18 GMT
Yes that one I found. I also downloaded the according PDF with pictures.
The issue is under investigation.
Post by edwinwl on Jul 10, 2011 18:25:00 GMT
Last week was plumbing time! I am rising the center tunnel by 2,5 cm (1 inch) so more space and easier to mount the aluminum tunnel (spout on proper English?).
vtR1k
Post by vtR1k on Jul 11, 2011 8:33:34 GMT
Nice! Did you already had the opportunity to think about the handbrake? I'm wondering how to fit the handle...
Post by edwinwl on Jul 11, 2011 14:52:17 GMT
vtR1k
Post by vtR1k on Jul 12, 2011 19:43:03 GMT
Thanks. I already fitted the caliper, but wondered how to fit the handle. I have another solution for the caliper by the way... Mine slides along with the weel in case of adjusting the drivechain. Also, my normal brake caliper is fitted on the upper side of the disc (model 2004...)
Post by edwinwl on Jul 13, 2011 10:42:25 GMT
I thing the RTR solution is only there so the car will pass IVA. I am having doubs that the handbrake is good working. You caliper fitting solution is very neat! I think mine will be mounted with an aluminum spacer. BTW Do we need a handbrake in the Netherlands to comply with Dutch RDW legislations? Officially in the Netherlands the tR1ke is a "motor bike with three symmetrical placed wheels". And I have not seen a passage that stated a handbrake must be present?
