Post by welshmarks7 on Apr 19, 2020 22:28:05 GMT
Hi guys, I'm after some info before I apply for my IVA.. Do the coil over nuts require radius covers for the IVA, I'm sure I've seen a couple of threads where both with and without have been acceptable. I'm just after a reassuring reply if you can help please.
Post by perthwa on Apr 22, 2020 5:52:14 GMT
In Australia: ( for those interested)
5. General specifications 5.1. The provisions of this Regulation shall not apply to those parts of the external surface which, with the vehicle in the laden condition, with all doors, windows and access lids etc., in the closed position, are either:
5.1.1. At a height of more than 2 metres, or
5.1.2. Below the floor line, or
5.1.3. So located that, in their static condition as well as when in operation, they cannot be contacted by a sphere 100 mm in diameter.
+++++added by ME++++ if a 100mm circle (aka your Head radius) can't hit it because of the other "correctly shaped" stuff around it then it is OK.++++++ +++Otherwise+++++++ it must be covered or meet minimum radius++++++
5.2. The external surface of vehicles shall not exhibit, directed outwards, any pointed or sharp parts or any projections of such shape, dimensions, direction or hardness as to be likely to increase the risk or seriousness of bodily injury to a person hit by the external surface or brushing against it in the event of a collision.
5.3. The external surface of vehicles shall not exhibit, directed outwards, any part likely to catch on pedestrians, cyclists or motor cyclists.
5.4. No protruding part of the external surface shall have a radius of curvature less than 2.5 mm. This requirement shall not apply to parts of the external surface which protrude less than 5 mm, but the outward facing angles of such parts shall be blunted, save where such parts protrude less than 1.5 mm.
