Post by vulcanuk on Apr 14, 2019 10:12:33 GMT
Hi,
my dad and I are thinking on making an Exocet, however we have a detached garage that only fits a car and has no space to make any modifications. Has anyone else had the same problem? If so, how did you get around it?
It may sound like a silly question, however any help will be appreciated.
many thanks
Sam
Post by slowgo on Apr 16, 2019 7:49:22 GMT
If you buy an MX5 then you can do most of the prep work before you fit the kits frame to it. Then build up you clean painted skate and cover it over outside while you fit the floor pans and pipes to the kit, (about a 1 day job) then you can mate the 2 together and all will fit back in the garage as a car on wheels. You will need space to store body parts while you build but most will fit in the loft or a shed? Hope this helps.
