Post by stevew on Aug 30, 2018 11:46:23 GMT
Purchased a '96-2000 gear lever but it looks different to that shown in the build manual. Is it the wrong one? Steve
Post by stevew on Aug 30, 2018 14:12:13 GMT
Well it looks as though I can make this one work. Took the nuts, joining plates and rubber spacers out and fitted the focus rubbers and top hats. Looks like I just need to trim off the built in cable holders and I'll be good to go. Steve
Post by buildityourself on Aug 30, 2018 20:46:30 GMT
Yes thats different to the one I got from the correct 96-2001 Mondeo, but the action looks the same. Mine is steel and heavy, so this one may be lighter. How much does it weigh? Can you see any date stamps on it?, normally dots in a grid for year/month.
Post by stevew on Aug 31, 2018 6:18:50 GMT
Hi Stu The only marks on it are etched onto the side and are (illegible characters replaced with ?) XS7R-75? -6C 05.11.99 11H So it looks to be from the correct period. Steve
Post by Stiggy on Aug 31, 2018 8:49:03 GMT
You have one of the optional gear levers that will work. The rearward position is limited due to the handbrake location. I suggest you sit in the car and see if the forward reach is OK when locating 1st. The lever can be bent if required and you may want to shorten the lever as it looks tall and may be a long shift.
Post by stevew on Aug 31, 2018 8:57:10 GMT
Many thanks Stuart. I'll do as you suggest once I have the car in a position I can get in it. It's reassuring that you think it can be made to work.
Steve
Post by drbrian on Sept 29, 2018 14:11:06 GMT
What engine do you have?
