Post by ju55ean on Apr 5, 2018 21:31:18 GMT
Good evening ! I purchased a wicked rocket couple weeks back now, some of you may no as KATE. Having much fun with her but also had a couple dramas. I’m curious to see if anyone has had this problem. Hopefully u can see the picture. It’s the engine mount. Thanks Sean image url
Post by ju55ean on Apr 5, 2018 21:32:50 GMT
Post by kiwicanfly on Apr 5, 2018 21:44:44 GMT
I had a similar problem but bent in the other direction.
I straitened the original mount then made a top and bottom plate from 6mm aluminium sandwiching the orginal mount.
Then made a 6mm spacer plate for the engine which I put under the mounting plate to return the engine to level.
Post by Stiggy on Apr 5, 2018 21:56:18 GMT
I would check the torsion mount, (in the middle at the back on the lower chassis rail) This may be weak and allowing excess movement, which would allow excess engine rocking, which would allow the centre bolt on the bent mount to pull up as it rolls.
You can support the engine and remove the mount in question, hammer back to shape.
A little worrying that there is no sign of base coat on the powder coating and rust has taken hold on that mount. You should check every where on the chassis for bare metal, remove rust and touch up straight away before it spreads.
Post by casesensitive on Apr 6, 2018 7:37:32 GMT
To me it looks like two things; the powdercoat wasn't primed properly, so you're getting sub-surface rust; you'll have to strip it back and do it over; probably with paint.
Second thing; the bending direction suggests to me that the car was lifted from underneath, supported at the gearbox or sump. Is there heavy scratching or indentation on the places that the jack would have been placed? My engine is currently suspended by the gearbox while I cut off the gearbox mount to move it. Hard to imagine the bouncy-bouncy of driving would cause that.
Great car though, serious go in Kate.
Post by kiwicanfly on Apr 6, 2018 7:50:20 GMT
Also I note that although a nylock nut was used there does not seem to be threads protruding through the nut which is a requirement for them to work.
Ideally two threads minimum should protrude.
If the thread is simply too short then use a lock washer under the nut.
Post by ju55ean on Apr 8, 2018 14:24:07 GMT
Hi, thanks for all the replies. So I’ve fixed Kate, the black plate was in the wrong place. It should of been under the square plate not above it. We had a good run yesterday all day until.... her clutch went. So she’s back in the garage having a new clutch. Uprated to a 5 paddle clutch with Castrol srf racing fluid from CG motorsport. Hoping she be back ready for next weekend.
I’ve just found out about the kit car meet in May. How do I jump on the band wagon for this ? I would love to cruise up and meet you guys? Or get on stand with Kate ? Any help is much appreciated Thanks Sean
Post by p5curly on Apr 8, 2018 18:55:28 GMT
Are you talking about stoneliegh in may if so just turn up with your kit and park on the MEV grass spot with the rest of us
Post by ju55ean on Apr 10, 2018 6:49:33 GMT
Yea that’s the one. Il keep an eye out for you guys. Cheers
