Post by ju55ean on Mar 24, 2018 16:50:32 GMT
Hi there,
Was wonderful if anyone else has trouble with the fuel gauge working ? Mine seems to be stuck on full? Kinda annoying as I run out of fuel Other day lol haha forgot to check. Would be nice if it worked
Thanks Sean
Post by ju55ean on Mar 24, 2018 16:52:09 GMT
Post by snowbird1 on Mar 26, 2018 14:34:14 GMT
Acewell gauges usually can be set for different sensor resistances, basic check - disconnect sensor wire at fuel tank and short to ground, gauge should show full and empty if circuit is OK.
Post by casesensitive on Apr 13, 2018 8:48:42 GMT
The first question I'd ask is did you change the length of your sender arm when you went from donor tank to MEV/RTR tank? Ford Focus tank is ~12c high, RTR one is 30cm, so that'll make a huge difference. My Koso gauge isn't natively the same 'way up' as the Ford console; low resistance is full rather than empty. The best way, and it's not cheap at £40, is to stick a Spyda fuel gauge wizard between your gauge and sender. You set the empty, 1/4... all the way to full on the gauge with one setting, and the same 5 graduations for the fuel in the tank with another setting. So whatever shape your tank is, and whatever way your gauge interprets that isn't important, it'll always be spot on. I got mine for £30 at Stoneleigh, and no postage either, so if you're there, definitely pick one up. mevowners.proboards.com/post/102145/thread
