Post by stuli on Apr 22, 2019 10:19:18 GMT
Hi Paul PM sent with sketch of wiring as described in previous post. Tho only change is to switch a relay (using the switched ground) when main beam is selected, and use that relay to supply a live feed to the Dominator main beam bulb. It makes sense to use 2 relays (one for each side) given that the MX5 already has a left / right split on live feeds, and maintaining that split will ensure you don't overload any existing wiring. Cheers Martin Looks like I will have the same issue can you share the diagram if possible? Cheers and good luck!
Post by p2tav on Apr 22, 2019 15:58:52 GMT
Post by p2tav on Apr 23, 2019 19:12:39 GMT
final checks, 1/ who understands the wing mirror check ? if so can someone explain it to me please ? 2/ it is my understanding the wing mirrors don't have to be c marked if they are fit for purpose is this correct ? 3/ with dominator 2 head lights which side does the dipped beam go on? inside or outside? any help would be good cheers
Post by Stiggy on Apr 24, 2019 9:14:37 GMT
Post by p2tav on Apr 25, 2019 16:58:35 GMT
Post by p2tav on May 2, 2019 14:30:35 GMT
Post by miket on May 2, 2019 15:36:59 GMT
Looks great Paul - good work. If you haven't already; you can buy a 100mm diameter polystyrene ball for a couple of quid in the crafts section of eBay etc and use it to simulate the IVA test.
The only question mark I could tell from the pics was the edges on the bananas.
Post by p2tav on May 3, 2019 0:44:40 GMT
Looks great Paul - good work. If you haven't already; you can buy a 100mm diameter polystyrene ball for a couple of quid in the crafts section of eBay etc and use it to simulate the IVA test. The only question mark I could tell from the pics was the edges on the bananas. cheers Miket, will do and also have a look at the bananas but dont think you can get ball anywhere near them but will check cheers
Post by jleigh5 on May 3, 2019 8:10:38 GMT
Looks very good! I believe you need an Interior mirror (even if you can't see out of it!) Can you see the indicators from 45° the other way when they are mounted on the wheel arches?
Post by p2tav on May 3, 2019 11:18:25 GMT
hi buddy mikeyboy is lending me rear view mirror and indictors are 20deg as bellow 750mm cheers paul
Post by ian85 on May 3, 2019 12:32:25 GMT
hi buddy mikeyboy is lending me rear view mirror and indictors are 20deg as bellow 750mm cheers paul Don't worry about the indicators, as my g type passed the iva with them last Friday.Only thing that came up is the rear facing side indicators can be blocked by your wing mirrors when viewed from behind
Post by p2tav on May 4, 2019 9:40:19 GMT
just been for pre MOT all passed lights pass indicators pass brakes pass emissions pass really please with outcome I know iva has many more checks but hopefully they can be sorted on day fingers crossed, it drove really nice on the road too
Post by hammy3601 on May 4, 2019 14:34:48 GMT
Nice one!
Post by markwill on May 10, 2019 14:32:52 GMT
Wow, just realised I seem to have copied your colour scheme and the fact that you've retained the heated seats. Looks awesome BTW!
Post by hammy3601 on May 11, 2019 7:08:02 GMT
Its you and me this week Paul! Best of luck mate
