Post by p2tav on Jan 29, 2019 17:30:16 GMT
Also when are you thinking of going for IVA mate? Happy to lend you any of the bits that I use after my IVA cheers buddy
Post by p2tav on Jan 29, 2019 17:41:09 GMT
taken hrs for me to finally decide where to fit the fog light switches and heated seat ones finally decided to put them here.
Post by jason82 on Jan 29, 2019 20:25:38 GMT
Just a thought, regarding the mesh idea around the master cylinder, why not use the large stainless p clips with the rubber insert to go around the chassis, then bolt the mesh to the clip fixing hole ?
Post by p2tav on Jan 29, 2019 20:35:50 GMT
Gents,
I have just fitted the hazard switch in my car I have used the original one does it have to flash or light up as mine does not ? it does tell you on the dash is that ok ?
Post by stevew on Jan 29, 2019 20:44:45 GMT
Gents, I have just fitted the hazard switch in my car I have used the original one does it have to flash or light up as mine does not ? it does tell you on the dash is that ok ? I think providing both indicator warning lights flash, then it is OK. Cheers Steve
Post by martinw on Jan 29, 2019 23:44:26 GMT
ive just been told if I use the wing mirrors that I have purchased I need to disconnect the indicators on them as you are only allowed one per side so with the ones on the wheel wings I will have to remove the ones on the mirrors ? has any one else heard this ? Yes; IVA Manual Section 23, and accompanying table 1. Correct number of side repeaters is 1 on each side. Hasn't changed since my IVA back in 2011. Nothing to say you can't just disconnect one or the other; just make sure that you leave one which adheres to the rules for visibility. Martin
Post by hammy3601 on Jan 30, 2019 8:12:37 GMT
taken hrs for me to finally decide where to fit the fog light switches and heated seat ones finally decided to put them here. Paul, are you using seat belts or harnesses mate? You have to be able to reach the switches when fastened into the seat mate.
Post by jason82 on Jan 30, 2019 9:54:10 GMT
Regarding the hazard switches, Browno' s car past iva with them in an identical position to yours, I have mine in the same place along with the display dimmer & fog. Look on his build thread, it's in the Exocet page 3, look for Browno & it's on his build page 5. His car past first time & he was using harnesses.
Post by jason82 on Jan 30, 2019 10:12:06 GMT
Gents, I have just fitted the hazard switch in my car I have used the original one does it have to flash or light up as mine does not ? it does tell you on the dash is that ok ? My one illuminates. I believe that it must illuminate as a 'tell tale ' sign. For clarification, use the technical email address that I shared with you. If they say that it must illuminate, don't rush out & buy a new switch, take the switch apart carefully, 2 springs will pop out, then slide out the hazard switch and you will see that it has an led in the pcb (printed circuit board), just solder in a new white led. It gets it's red colour from the painted legend on the face of the switch, if you put a red led in, it may be too dark to see.
Post by p2tav on Jan 30, 2019 12:08:45 GMT
taken hrs for me to finally decide where to fit the fog light switches and heated seat ones finally decided to put them here. Paul, are you using seat belts or harnesses mate? You have to be able to reach the switches when fastened into the seat mate. seat belts buddy so should be fine
Post by hammy3601 on Jan 30, 2019 12:35:23 GMT
Cool, it seems it's one of those discrepancies that keeps coming up with some passing and some failing. I know a few have failed and yet many passed. Good old IVA eh! :-)
Post by hammy3601 on Jan 30, 2019 15:53:20 GMT
Just checked on my mk2 (on the road car not my Exocet) the switch doesn't illuminate, just tell tales on the dash. In my other daily it doesn't illuminate either just tell tales again on dash. As suggested already Id check as the manual is a bit wooly and reads as follows:
9. The hazard warning device must have a telltale warning light (see Note 1)
You could read that as the tell tales are there on the dash......
Post by hammy3601 on Jan 30, 2019 17:44:09 GMT
Just confirmed by a couple of others that have passed IVA with dash tell tails only mate! Good news for ya :-)
Post by p2tav on Feb 10, 2019 17:39:41 GMT
Gents,
any ideas with regards the bonnet fitment as I cant get it back far enough due to radiator ? I have the rad fitted as far back as it will go but it still is stopping bonnet going back? is there a smaller rad that will fit with a smaller fan ?
cheers paul
Post by p2tav on Feb 10, 2019 18:15:53 GMT
Gents, any ideas with regards the bonnet fitment as I cant get it back far enough due to radiator ? I have the rad fitted as far back as it will go but it still is stopping bonnet going back? is there a smaller rad that will fit with a smaller fan ? cheers paul found this on ebay 232601340577 please type number in and give me your opinion any good
