Post by shelleyx191 on May 17, 2017 10:35:16 GMT
Inadvertantly when dismantling the old body we did not save the locks or catches which parts do we actually need Thanks
Post by Deleted on May 27, 2017 7:09:26 GMT
You need the mechanism that was fixed inside the doors including the release lever, not sure of the proper terms but basically everything except the locks. No reason why you have to use the MX5 bits as you could probably adapt most door mechanisms. I actually made the same mistake but ended up with an MX5 for another project so took the door parts from that car.
