Post by miket on Dec 18, 2016 10:17:33 GMT
I hope there's no iva issue with venting tank to air 'cos it's as per Build Guide... "If you do [remove canister] then you can leave the pipe open after the check valve on the tank to allow for evaporation without a vacuum forming."
Sorry - I've no experience of air bag issue.
Post by chrisbucks1 on Dec 18, 2016 17:46:49 GMT
Thanks miket think I can figure out the air bag issue I'm going to try excessive force !!!
Post by gwnwar on Dec 18, 2016 21:38:22 GMT
Just unbolt it from under the dash after removing glove box.. no force needed.. 1/2 volt will set air bag off.. not a play toy after out..keeps kids away..
Post by chrisbucks1 on Dec 18, 2016 22:01:19 GMT
Just unbolt it from under the dash after removing glove box.. no force needed.. 1/2 volt will set air bag off.. not a play toy after out..keeps kids away.. Thanks gwnwar got the airbag out. Question regarding axle bolts do you take wheels or go through center cap ?
Post by chrisbucks1 on Dec 18, 2016 22:01:37 GMT
Going to make vlog series of my build here is episode 1 .
Post by davetherave on Dec 18, 2016 22:16:19 GMT
Hi Chris we're about sin bucks are you I'm in Berkshire so not far
Post by chrisbucks1 on Dec 18, 2016 22:48:38 GMT
Hi Chris we're about sin bucks are you I'm in Berkshire so not far Hi Dave I'm in Aylesbury. Be great to get together email me info@a1martialarts.co.uk
Post by gwnwar on Dec 19, 2016 6:31:28 GMT
With the axle nuts. leave wheels on just remove center caps.. That way you have the weight of the car and brake system to stop wheels from spinning..The nuts are staked down knock it up.. I use an old screwdriver ground down to fit in slot. It must be 40 years old now.. A good 4 foot pipe on end of breaker bar helps.. air impact works most of time if you have one..
Post by chrisbucks1 on Dec 22, 2016 22:50:32 GMT
thanks gwnwar got the axle bolts loose!!! Next question what is this ?
Post by chrisbucks1 on Dec 22, 2016 22:53:28 GMT
do I need to use these connections in the Exocet ?
Post by chrisbucks1 on Dec 29, 2016 22:37:11 GMT
Quick question I undid the rear axle bolts do I need to do the front ones as well if so is there a trick to get dustcaps off.
Post by Stiggy on Dec 29, 2016 22:58:17 GMT
the rear ones do not need to be removed but the front hubs need to be removed to fit the wings stays behind them. You may need to dent the dust caps to get them off but as long as you do not puncture them you should be able to get them back in shape.
Post by gwnwar on Dec 29, 2016 23:41:31 GMT
Use a small chisel between the cap and hub. keep going side to side to move it. Then keep tapping it off or grab it with a large pair of water pump pliers or pliers made for grease caps removal and work it off. If you are going to powder coat the rear parts you will need axle nut off/loose to take apart..
Post by chrisbucks1 on Dec 30, 2016 9:52:31 GMT
Thanks gwnwar ant Stuart one more question removing clutch master cylinder do I do it now or wait till the body is off the rollerskate and what is the procedure for removal ? Thanks in advance
Post by Stiggy on Dec 30, 2016 13:32:53 GMT
