Post by jgilbert on Feb 24, 2015 20:40:46 GMT
I reckon John Gilbert or you Trident should start a business to finish kit cars or build them for customers. Mate that's a very nice comment to make and I appreciate your kind words but it's taken me about three and a half years to get to where I am now and still not finished. I don't think it would be a very viable business. Mind you … No may be not. HaHa, agree nice comment. Let's see if we can get our cars IVA'd first. Trident, I'm on a 2 year timeline to retirement, so providing we both manage to finish our cars then never say never!
Post by tlight on Sept 29, 2015 18:54:20 GMT
Big thank you to Snowbird (John) for getting my car running & sorting all the snags. Some of the items he sorted... Stripped harness Tidy wiring Improved fuel system hose routing Wings Fuel tank cover access, via bent tank & removal of reversing lamp Running motor... Just one snag I need to resolve at the moment, any suggestions on sorting the exhaust in the midlands ?
Post by Stiggy on Sept 29, 2015 19:41:02 GMT
Tim, my goodness, so glad you came back. I spoke to Snowbird and heard he was helping. Brilliant.
Post by tlight on Oct 3, 2015 17:54:36 GMT
Today started measuring up and fitting nut caps and edging trim. Fitted black around headlamp brackets and white around the nose cone.
Already covered the suspension arms, measured up the wings and seats for white and red trim.
Do i need to cover the seat belt belt brackets, it's about 6mm plate ?
Post by tlight on Oct 18, 2015 13:33:44 GMT
Trimmed wings & seats with edging strip today. E marked reflectors fitted to chassis at the top of the suspension mount.
Post by tlight on Dec 24, 2015 12:07:43 GMT
Read in IVA manual under Section 16 Exterior Projection. " 29. An exhaust tailpipe must not project beyond the floor line lying directly above it by more than 10mm, unless it terminates in a radius of curvature of at least 2.5mm and in all cases project no more than 150mm. In the case of side mounted exhausts the tailpipe must terminate no more than 50mm from the extreme outer edge of the vehicle. " so I've shortened the tailpipe and added a £4.95 Ebay tailpipe on the end.
Next job fuel tank shield, IVA compliant side marker & seal transmission tunnel...nearly done...
Post by p5curly on Dec 24, 2015 13:39:33 GMT
Just noticed your post did you sort your exhaust out
Post by tlight on Dec 24, 2015 13:52:07 GMT
Hi, I think this is now compliant to IVA
Post by tlight on Dec 24, 2015 13:58:02 GMT
Side marker made out of a motorbike indicator, and a turned piece of tube to mount to a Rivenut in the chassis, turned down to indicator body diameter to avoid 2.5mm radius, male M8 thread one end of the tube, slotted on underside for cables and M10 tapped hole the other end to mount indicator. Thanks Noel !
Post by p5curly on Dec 24, 2015 14:09:25 GMT
We had to stick ours on wings as it was Iva fail yours seem ok where are you looking to Iva it at
Post by driver on Dec 24, 2015 22:49:23 GMT
You got snowbird to do the wiring for you? I'm looking for someone to strip my harness too. Point him in my direction if you get a hold of him. Thanks
Post by tlight on Dec 25, 2015 11:26:35 GMT
Last time I spoke to Snowbird is was traveling back to the states for about 6 months. He's on this forum, look at his Replicar build.
Post by tlight on Jan 5, 2016 15:26:14 GMT
Side marker tube machined and ready to fit
Post by tlight on Jan 5, 2016 15:27:35 GMT
Hope this works out OK for IVA
Post by rob180bhp on Jan 5, 2016 20:04:01 GMT
It might be a problem as it's facing the wrong way lol
