Post by p5curly on May 13, 2016 18:41:55 GMT
How you holding out I sent my apprentice with you I hope you are showing him how its done
fatboy
Post by fatboy on May 21, 2017 11:48:17 GMT
Its been a long time since I posted on my rocket thread but thought it was about time I did. I've been checking my tyres out and they still have loads of tread left but they seem to be spinning up quite a lot. I bought the wheels and tyres in 2010 so the rubber should be about 7 years old you would think. so I suppose the rubber will be starting to go off. Did a bit of research on line and tyre rubber should last up to 10 years so mine are well with in that time period you would think Not so I also checked the DOT date code on the tyres to find they were manufactured in 2005 so that might explain the lack of grip. So a word to the wise if you buy a wheel and tyre package check the date on the tyres as kit cars are light they don't tend to wear out the tyres just the rubber goes off
Post by p5curly on May 21, 2017 12:28:28 GMT
So are you going to put fresh rubber on your car Are you going to stick with the same tyre make
fatboy
Post by fatboy on May 21, 2017 16:46:06 GMT
I'ts ether nanking ns2r or toyo r888r
Post by p5curly on May 21, 2017 17:03:05 GMT
We have nankangs on our yellow one and they very grippy in the dry
fatboy
Post by fatboy on May 28, 2017 14:59:51 GMT
Tyre update £300 spent on Nankang ns2r and 2 day's spent on castor,camber,tracking and suspension settings and wow I am now driving the car as opposed to fighting it at speed.
Post by kiwicanfly on May 28, 2017 17:59:10 GMT
Do you have any settings you care to share?
fatboy
Post by fatboy on May 28, 2017 18:10:38 GMT
Ride height 120mm front 135mm rear Rear camber 1 degree negative 0 tow in Front castor all the way back with 1 degree Negative camber and tow in by 1 degree Front damper 5 clicks rear 7
