Post by mawdo81 on Oct 8, 2015 16:35:33 GMT
You won't be able to start a pm till 20 posts...so get posting or fatboy can pm you...
fatboy
Post by fatboy on Oct 11, 2015 18:13:54 GMT
Drag racing today 2nd in class 14.2 sec 92 mph 1/4 mile Also managed to burst engine mount
Post by sandancer73 on Oct 12, 2015 18:54:22 GMT
Where were you Paul?
fatboy
Post by fatboy on Oct 13, 2015 15:59:51 GMT
Hi mate I was at York dragway
Post by sandancer73 on Oct 14, 2015 11:44:48 GMT
Hope you had a fun day.
fatboy
Post by fatboy on Apr 1, 2016 15:44:50 GMT
At last I have managed to fit the light weight flywheel (9kg to 3.9kg) you have a 2.0 pressure plate a 1.8 friction plate and a 5mm adapter between the gearbox and the engine . It all turns over ok so I'll refit the engine tomorrow and see what happens (fingers crossed)
fatboy
Post by fatboy on Apr 2, 2016 14:57:25 GMT
IT'S ALIVE Revs like a bike tax it tomorrow see what happens.
fatboy
Post by fatboy on Apr 3, 2016 10:21:10 GMT
Just took it out for a test run goes like a scolded cat only down side 1st not much good if you floor it just spins
Post by airforceone on Apr 5, 2016 6:04:14 GMT
Is it just a standard IB5 box you have with the lightened flywheel.
Been looking at fitting one of these myself and thought it was just a straight replacement along with my 1.8 clutch kit. What is the adapter plate for??
fatboy
Post by fatboy on Apr 5, 2016 11:54:47 GMT
HI airforceone if you have your flywheel lightened then there is no need for the plate but if you buy a billet flywheel as I did they are designed for 2.0 engine and box so they will fit the engine but there are clearance issues with the box. So I had a 5mm plate made to kick the box out slightly (I also removed a couple of the cast webs inside the bell housing) The other option is to replace the box with a 2.0 but gear cables in different place drive shafts are different (so I was tolled) so I thought stuff that hence the adapter plate hope that helps paul
fatboy
Post by fatboy on Apr 10, 2016 17:52:35 GMT
Just been for a blast round the Yorkshire dales back end not very stable at speed . Found out why rear hub nut had come loose so changed pants and retightened took it back out and all ok now
Post by BobN on Apr 10, 2016 18:06:33 GMT
The castle nut was loose? Had that problem too in the early days.
fatboy
Post by fatboy on Apr 10, 2016 18:52:38 GMT
Yup its dead good you find the colour of adrenalin (its brown and runs down your leg)
fatboy
Post by fatboy on Apr 18, 2016 16:44:40 GMT
fatboy
Post by fatboy on May 13, 2016 17:20:13 GMT
On the 7th brake down on the European trip only 3 faults though main one being gear linkage (5 times) ?
