Post by westie66 on Apr 28, 2016 15:58:48 GMT
Are you going to Stoneleigh this year? would be good to meet up.
Post by john on Apr 29, 2016 13:14:18 GMT
Afraid not I've got to work that weekend otherwise I would have liked to go , I know the show would give me lots of ideas and a kick up the arse !
Post by john on Apr 29, 2016 15:48:35 GMT
Few little bits mainly just located the water bottle rivnut for the top and made a bracket for the lower mount just need to order a longer hose to reach top of radiator. Mounted ecu on top with two rivnuts and a bit of foam underneath to protect it. Then looked at the loom, that's all I did as well look at it.
Post by westie66 on Apr 29, 2016 21:10:56 GMT
The loom looks bad when it is laid on floor or stuffed in a box. Get it laid out on the car and it will not look too bad. Honest.
Post by john on Apr 30, 2016 23:13:40 GMT
Just ordered rad hose from top of rad to expansion bottle and gear stick gaitor hopefully next week I'll fill it with water then may look at loom and try and see what's what.
Post by john on Apr 30, 2016 23:14:49 GMT
Let me know what you plan on trimming out of loom as loads can be junked just need to think about any earths or shared components I guess.
Post by westie66 on May 3, 2016 5:54:59 GMT
Best method for the loom is leave it intact, put it on the car and connect up what you can. Next you need to get the engine running. Once you have a running engine and stuff like gauges and lights working you can look at stripping some stuff out. A good starting point will be the wires that went to the doors, the radio wiring and heater controls. You will lose some of the earths but the main multiple wire earth points are not really impacted by the wiring you will be removing. Stripping the loom when it is on the car also helps keep the bundles together and you can work out where you will need to extend some of the connections. Good luck.
Post by gwnwar on May 3, 2016 16:34:57 GMT
Do as westie66 wrote.. Once you have it running remove harness cover and tape put slip ties on LOOSE to hold wires in place and you can slip out wires to remove.. Some ground and power wires go to a couple of things only cut to a joint of wires.. You can cut more later if needed.. Leave a little wire tail at each cut in case you have to put cut wire back.. Print this off in color and put in plastic sleeves to use in garage.. www.mellens.net/mazda/mazda_miata_extra_manual/1999_wiring.pdf
Post by john on May 4, 2016 17:33:36 GMT
Thanks gents, finished expension tank today and filled up with coolant and made a brake line left to right along bulkhead but not flared yet as mates got the tool.
Started on the wiring loom just a small section just the engine sensor side but I've a few left over ha ha I'll start properly next week when I've got a few hours off.
Post by john on May 11, 2016 13:25:26 GMT
Side tracked slightly couldn't find a gear stick gaiter that fit properly my cut out for the gearstick was slightly to big. Made a new aluminum panel which sits nice and flush with the gear selector and fitted a gaiter.
Started to look at the loom and droop it over the car just wished I'd labelled everything as I have missed a few.
Post by john on May 11, 2016 13:26:14 GMT
Post by john on May 15, 2016 19:18:09 GMT
Small steps today but steps all the same, mate came round and helped with some of the steps I've not dome before. Firstly though was the biscuits, not bad but don't think ill bother again. The clutch has now been bled and is now working and engaging gears took a while to get the airlocks out. The rear brake line has been flared and fitted the front near side pipe flared but didn't get any further without sorting out the bracket that joins the hard fixed pipe to the flexible section so these were made and fitted. Some jobs ticked off one more session should see the brakes finished and clipped up etc. The lad helped he steer the car back into the garage.
Post by gwnwar on May 15, 2016 20:15:48 GMT
Good looking lad big smile helping dad.. made his day.. Like the brake line bracket first time seen done that way/shape looks good.
Post by R2S on May 16, 2016 11:54:55 GMT
Good looking lad big smile helping dad.. made his day.. Like the brake line bracket first time seen done that way/shape looks good. I too like the brake line bracket, very neat, may be seen somewhere else in the near future (guess where).
Post by john on May 19, 2016 21:51:13 GMT
Hope it helps I've taken loads of tips and advice of everyone else glad my build could help someone else.
I also have a load of the fuel and brake line clips I used available as I had to bulk buy 100 from the supplier.
