Post by snowbird1 on Dec 14, 2015 19:30:46 GMT
Post by gwnwar on Dec 14, 2015 23:23:46 GMT
You can switch wheels NA> NB NB> NA the difference is the clock spring unit. The problem is the 2 tits that cancel the turn signals are 12 and 6 on NA and 3 and 9 on NB wheel. I know you can drill 2 new holes in the back of the NB wheel to use on NA shaft.. Have not tried NA to NB drilling then might be enough space.. Do you need self cancel turn signals for IVA?? Horn wire is just a ground supply to relay..
Post by mawdo81 on Dec 15, 2015 21:15:47 GMT
No need for self cancel for IVA
Post by Deleted on Dec 16, 2015 6:30:24 GMT
Mawdo81 is spot on, need indicators and hazard lights with a tell tale on the dash. I fitted an audible buzzer for a motorbike as it can be hard to see if you have an indicator going in an open top car.
Post by Deleted on Dec 16, 2015 6:32:51 GMT
Has anyone looked into copying the wing mirrors from the original? Bit of a funny setup with a post going between body and screen but would look good if done. Merlin Motorsport do a mirror for a single seater that is a close copy for the original mirror if the post can be made.
Post by mawdo81 on Dec 16, 2015 7:22:10 GMT
You only need a tell tale if the indicators themselves can't be seen clearly looking forwards from the driving position.
Post by p5curly on Dec 16, 2015 14:06:59 GMT
I too fitted audible buzzer as its hard to see clocks through wheel and it meant you can keep eyes on the road
Post by Deleted on Jan 3, 2016 11:10:36 GMT
Things are moving along, got my collection dates from Stuart for the kit. Going to have to get a van as my current daily drive doesn't have a tow bar even though I have a trailer. Will be collecting mid Jan so just had a big garage tidy to make space. Already got new wheels on order and a few other parts have already arrived.
Post by john on Jan 15, 2016 22:22:41 GMT
I've just ordered a batch of those clips in my thread I think they should hold the two 8mm outer diameter fuel lines and the 3/16 perfectly along the chassis means just one hole and could be a good solution. Hopefully they will be with me mid next week and if they do the job maybe useful.
Post by Deleted on Jan 19, 2016 7:54:01 GMT
Post by john on Jan 19, 2016 12:30:03 GMT
Looking good mate (I'm biased I know) glad to see the 'car in a van' being used its a tight fit but perfect solution.
The clips I ordered have arrived and fitted them today, have a look at my thread I can sort you some out if you decide you going down that route.
Hope you had safe journey back.
Post by R2S on Jan 20, 2016 22:59:19 GMT
Post by Deleted on Jan 21, 2016 9:09:02 GMT
Hi John, already stocked up with P-clips, plus I have decided to get some assembly done before I run the pipework, just to give me a better fit. I have one of those drill accessories that turns the bit through 90 degrees if space is tight. Unfortunately the pop rivets were not in stock when I collected so I have cut and drilled the floor but waiting for the post before I can fit. To keep me busy i have been cleaning up the pedal box. I might get the headlights fitted as well if nothing in todays post.
Post by john on Jan 21, 2016 22:28:19 GMT
Blimey you seem to be hitting the ground running , look forward to seeing updates.
Post by Deleted on Jan 23, 2016 16:05:37 GMT
