Post by Deleted on Sept 21, 2015 20:29:05 GMT
Second tank in tonight. One return pipe fitted and went in ok. Just need to do the other one then fill up and check for leaks. Quite a few jobs coming to light which I want to do. Re routing stuff etc etc. Hopefully try and finish it all off this weekend.
Post by OzExoNinja on Sept 25, 2015 1:08:36 GMT
Hi Adam, quick question, is your floor carbon fibre or alloy with a wrap on it?
Post by Deleted on Sept 25, 2015 5:59:34 GMT
I cheated mate it's the alloy that came in the kit (that's if you got it in the kit ) covered in carbon look wrap.
Post by OzExoNinja on Sept 25, 2015 7:17:02 GMT
It's all good Adam, exactly what I'm going to do as well!! Just wanted to see if anybody had gone to the effort (and what appears to be considerable expense!) of actually using carbon.
Post by Deleted on Sept 25, 2015 8:00:13 GMT
Only thing I would recommend is putting a heel plate where the pedals are. One to protect the floor plus I found the pedals quite high so lifting my heels slightly helped.
Post by mawdo81 on Sept 25, 2015 9:06:35 GMT
Love that, where's it from?
Post by Deleted on Sept 25, 2015 9:17:54 GMT
Post by Deleted on Sept 27, 2015 13:48:46 GMT
Both tanks now fully bolted in, Plumbed in,Seats back in and filled with fuel Fuel sender works perfectly. There's no leaks and they fit perfect with the seats. So really happy with them. Big thanks for sve to building exactly to my design and for the quick turn around. I have adjusted the position of the fuel pump as always thought is was a bit noisy. Thanks to kevs advice it's a lot quieter now. So thanks kev Just need to finish off tidying the back end up now and it's back on the road.
Post by Deleted on Sept 28, 2015 20:10:20 GMT
Spent an hour or so tidying up the rear end now the tanks are out. Managed to cut the clutch hose to length too and tidy up and secure all the wiring. Still want to do more in the respect of making it look better but it's road worthy now. Will sort the looks during the winter. Just the hydraulics to bleed and I'm all done. Hopefully the clutch will be sorted and then she's back on the road
Post by james13009 on Sept 28, 2015 22:12:36 GMT
Have you got the venhill clutch line, supplied with the kit?
Post by Deleted on Sept 29, 2015 5:19:58 GMT
Yes mate. Far too long for my application
Post by nigel on Oct 11, 2015 9:35:24 GMT
Love the nice neat fit of your new high capacity fuel tanks forward of the rear bulk head behind the seats @adam but was wondering whether it would be worth considering adding a stainless steel strap high up to prevent the tank from rocking and potential fatigue cracks from possibly developing in the tanks securing feet due to the acceleration/deceleration loads of such an extreme machine, just a thought.
nigel
Post by Deleted on Nov 27, 2015 9:58:22 GMT
I did consider this due to my original tanks in the original location failing due to the additional weight. The tanks have double sided high strength tape on the back of them and are stuck to the read panel, along with the 3 bolts holding them at low level. I can report back now that they are solid even when full of fuel. So all good.
regards
