Post by greyreplicar on Apr 12, 2015 10:29:42 GMT
Has anyone got any suggestions for mounting the radiator? I have used the original top mountings cut down and fixed to the top of the frame but struggling to find somewhere on the radiator to support the weight. Thanks.
Post by greyreplicar on Apr 12, 2015 10:35:47 GMT
Also, has anyone had to re drill the petrol tank in order to get it to fit? Decided to spray the tank to tidy it up.......... Not a good idea. The rubber coating on the tank has stopped the paint from curing and now it's like a sticky boiled sweet!
Post by stevednorris on Apr 12, 2015 12:45:49 GMT
I painted my tank a couple of weeks ago, spent 30 mins with acetone to get the rubber/glue off first and it came up lovely.
Building MEV Replicar from a 2002 MX 5 1.8 Arizona in Norfolk UK.
Post by R2S on Apr 13, 2015 12:44:40 GMT
Where in Sheff are you?
Post by snowbird1 on Apr 13, 2015 14:45:43 GMT
I used the OE mounts.
Post by greyreplicar on Apr 28, 2015 18:16:38 GMT
Post by greyreplicar on Apr 28, 2015 18:22:16 GMT
Has anyone had to cut out the back of the dash mould to enable the fitting of the instrument cluster? Looking at cutting it out as it would sit very low otherwise.
Post by greyreplicar on Apr 28, 2015 21:23:15 GMT
Post by R2S on Apr 28, 2015 22:13:50 GMT
Has anyone had to cut out the back of the dash mould to enable the fitting of the instrument cluster? Looking at cutting it out as it would sit very low otherwise. Pretty sure snowbird1 mentions need to do this in another thread but cant track this down at moment.
Post by R2S on Apr 28, 2015 22:17:55 GMT
You really mean Rotherham then I am originally from Ravenfield so know that part of the world quite well. I am progressing my build at the slowest rate I have ever done anything but once its built (you are only a 40 minute drive from my place in the Peak District) we'll have to meet up.
Post by snowbird1 on Apr 29, 2015 16:15:10 GMT
Has anyone had to cut out the back of the dash mould to enable the fitting of the instrument cluster? Looking at cutting it out as it would sit very low otherwise. I ground as much off the dash as I dared and trimmed the IP housing to fit, tight fit for the black connector.
Post by greyreplicar on Apr 29, 2015 16:49:08 GMT
Has anyone had to cut out the back of the dash mould to enable the fitting of the instrument cluster? Looking at cutting it out as it would sit very low otherwise. I ground as much off the dash as I dared and trimmed the IP housing to fit, tight fit for the black connector. Did you have to pack the Perspex off to clear the dial centres? Also, did you remove the wiring ribon and tuck it back afterwards? I am cutting the individual holes out of the dash for a bit more of a 'period' look, thought I had got it spot on but realised that I had set it too high after I had drilled the holes! Got to try and make it work now. Thinking about cutting a hole in the top of the dash and hope that the body can cover it.
Post by greyreplicar on Apr 29, 2015 17:01:39 GMT
Has anyone had to cut out the back of the dash mould to enable the fitting of the instrument cluster? Looking at cutting it out as it would sit very low otherwise. I ground as much off the dash as I dared and trimmed the IP housing to fit, tight fit for the black connector. Sounds like a plan.
Post by gwnwar on Apr 30, 2015 4:30:55 GMT
Instead of cutting the top of dash.. make a piece of alum with holes as needed and lower and make it go over toward the center of the dash and put your switches in it.. You could engine turn the alum too to look time period..
Post by greyreplicar on May 11, 2015 10:47:42 GMT
